Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 03-25-2005, 10:50 AM
mbr1965 mbr1965 is offline
Question Screeching Noise!
I have a 2001 Nissan Sentra GXE. For the past couple of months, when turning the wheel to the right, I get a screeching noise. As soon as I straighten out the wheel, the sound disappears. This does not happen if I am making a right hand turn from a stop, only when already in motion and there is a bend in the road. Any ideas what would be causing this and how much I'd be looking at to have it repaired?
Thanks.
Old 07-02-2005, 12:07 AM
Quicksilver7 Quicksilver7 is offline
Send a message via AIM to Quicksilver7
I have a 2003 SE-R Spec-V and I hear the same kind of noise but only once in a great while. It never works when I take it to get serviced of course, but I find it ususally does it when I back up and turn to the right, but not always. It is very unpredictable. Does this sound like your problem? My warranty runs out in less than 500 miles which will be less than 1 week the way I drive so if anyone can give me any suggestions as to what this would be or how to tell the mechanics to fix it, that would be great. Thanks.
Old 07-02-2005, 03:09 AM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
Re: Screeching Noise!
maybe brakes, occasionally they may rub if you turn a certain way, check your cv boots and joints as well
Old 07-06-2005, 02:57 PM
Andrewh Andrewh is offline
Power steering pump. It is the pump being over worked, and the belt slips. It usually does it a lock. Most times if it is a loose belt it will do it in either direction. But if it only does it in one direction, I am not sure i would worry about it. If you have had the belts replaced recently, then it might have the wrong tention on it. Do not over tighten though as it could cause other failures.
Old 07-06-2005, 03:42 PM
good call, forgot about power steering
Old 07-08-2005, 02:46 AM
slideways...'s Avatar
slideways... slideways... is offline
Re: Re: Screeching Noise!
THANK YOU!
it happened to my friend's 01 SE and i couldnt find what it was for the life of me (it really did sound like it was coming from the wheel)
although im half convinced its something else because it happens when the wheel is straight on her car and sometimes is continuous no matter how i drive, except it will stop when i drop below about 10 mph
unless this is because the pump or pump pulley is failing altogether, but that would be shitty on such a new car
i wonder if it would happen anyways on all b15 sentras because my friend hasnt touched her belts or anything yet(only 40k miles so they are good still)
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 07-08-2005, 02:53 AM
bump.....really need info/advice on this one!
