View Poll Results: how much horse power can you get out a 3000gt vr-4 with only 2000 dollers?
50-100 extra 1 20.00%
100-150 extra 1 20.00%
150-200 extra 2 40.00%
200-250+ extra 1 20.00%
Voters: 5. You may not vote on this poll
Old 03-25-2005, 10:28 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Question 3000gt vr-4 i just got some questions please help
so i just got a 92 3000gt vr-4 with a blow engine i am trying to figure out if i should/can replace the 92 engine and trany for a 6 speed 94 engine and trany?? how dificalt would it be to do? i will be doing the work myself on it.. and how are the stock clutchs in 3000gt's? when i have the hole engine out should i go a head ant throw a upgraded clutch on it? also wile the engine is out is there anything that i should do to it before i put it in? any info will help thanks!!
Old 03-25-2005, 10:33 AM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
the engine is the same so the six speed should fit right in. The stock clutch is good if your gonna leave it stock. the worst thing about the transmissions is the syncromesh, so you should replace them while your at it. sound like a fairly easy swap out job.
Edit: I just realized your gonna put in a new engine too along with the transmission. yes it will fit, I dont know how but your gonna have to change the shifter or at least the gate so that you can get it into reverse. the aftermarket clutch wont be necesary unless your gonna make loads more power.
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 03-25-2005, 04:47 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 3000gt vr-4 i just got some questions please help
There is no gate to change. Its all cables. If you get a 6 speed tranny you will also need a 6 speed rear end as its geared differntly.
Old 03-25-2005, 05:49 PM
jason_bet's Avatar
so would you sugest me just keeping a 5 speed in my car then? also i hear there is a difrence between the early 92 and the later 92 is this true? if so wich is better and how do you know?(wich numbers is the date made on the vin)
Old 03-25-2005, 06:09 PM
Stealthee's Avatar
Re: Re: 3000gt vr-4 i just got some questions please help
The difference is in the output shaft. 18 spline vs 25 spline. You will not have issues with that unless you are making regodamndiculous amounts of power.
Old 03-25-2005, 06:17 PM
jason_bet's Avatar
the output shaft? unformiliar with this? what would you sugest? should i go with the regular 5 speed? i know some about cars but im still new at it i have only been turning the wrench for about 4 months... is the 6 speed going to help me out a lot of even at all?
Old 03-25-2005, 06:20 PM
jason_bet's Avatar
also what is the stock pounds of boost on a 92 3000gt? and if i turn if up what is a safe pound to turn it up to?
Old 03-25-2005, 06:28 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Regular 5 speed is fine, I've owned a 5 speed SL and a 6 speed VR4 and I liked the 5 speeds gearing better lol. Go read the FAQ, it will answer your questions as well or better than we will (we're lazy somtimes).
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 03-25-2005, 09:44 PM
Stealthee's Avatar
LOL. Lazy isnt the word for it. There is tons of info to be found. If you dont already know about check out 3si.org. There is a ton of info to be gained from there.
Old 03-26-2005, 02:32 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
about the boost mod, check the FAQ in the "free boost" part
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 05-07-2005, 02:26 PM
Stealth-Twinturbo Stealth-Twinturbo is offline
The biggest problem with the stock boost solenoid is that it can't hold any boost to the redline. after 4000 rpm my boost went for 11 to 7, With the free boost mod. I bought a EBC and now i hold 12 psi right to the redline it makes huge difference.
92 Stealth R/T TT
CURRENT MODS:
K&N FIPK
Spec Stage 3 Clutch 6 Puck
HKS Turbo Timer Type-1
3 Inch Polished Y-Pipe
Greddy Profec B Spec II @ 12.0psi
Greddy Type S BOV
Greddy Catch Can
Borla Exhaust
3 Inch SS Down Pipe with Race Pipe
3SX Crank Pulley
Accel 8.0mm Wires
Gen 3 Lifters
High Flow 290lph Fuel Pump (Supra Pump)
Plugs Gapped at .030 Iridium IK20's
550cc RC Engineering
Apexi S-AFC II (WILL BE REMOVED NOT YET)
2 G-16 Turbos
AEM EMS
FUTURE MODS:
Custom FMIC
Old 05-08-2005, 01:04 PM
Igovert500's Avatar
blue + red light magnet
That is not the fault of the stock boost solenoid...that is the fault of our small 9b turbos. Regardless, something wasn't right if you were only holding 7 to redline, as you should be able to hold 10 to redline stock.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-08-2005, 03:57 PM
crazy_quick crazy_quick is offline
The newer 92's have a 25 spline output shaft, stronger then the 18 of course. And they also have a 4 bolt main as opposed to the 2 bolt main. The stock block is stronger and can hold more power.
