| Off-Topic Talk about anything other than cars. |
92 eclipse transmission
I was drive my Eclipse one day and it just quit goin and hasn't went since. It was drive fine and didn't give any signs of transmission failure. I've had transmissions go out in 4 cars so I know the usuall tell tell signs but didn't slip or gring or anything. It just stopped working. Could this be a hose or linkage or something??
I know the feeling
Hi I just posted a problem with my 91 eclipse. Sounds like the same thing. Let me know if you get if figured out as I will do the same. Good luck. See my post
Had the same problem with my 94 Laser. All gears were gone with no indication of tranny problems. Since ALL gears went out, I knew it had to be a pumping problem. Checked filter first. Pulled the trans and checked the pump and it was fine. Ended up being the torque converter. Ran like a champ for about 30,000 miles......now my gears are slipping....looks like no more easy fix.
Re: 92 eclipse transmission
2: Informing us if it's a 1.8, 2.0NA, 2.0T, or 2.0T AWD would yield much better posts then this one. BTW, pop your hood and use your eyes to look at the linkage cables (should I tell you where the linkage begins "interior" "hint" "hint"). You don't need 35 years of expierience to notice it's worn/broken
1993 Eagle Talon ES (4g63NA) 14.6 @ 98 mph (110 octane race fuel) -5 Speed Transmission (From a 4g67) -Stage 2 Crane cams -Ported and polished head -Aggresive valve springs -2.5" Custom made exhaust piping -Custom header -Gutted catalytic converter -Bored 0.5mm -Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC) -2g valve lifters (Lifter noise returned, now it a true DSM) -K&N w/modified air canister Last edited by macder; 09-17-2005 at 01:12 AM. |
I could only assume its auto fwd because thats the main one that has that problem...I should know, my 92 talon had an auto tranny that was changed 6 times and rebuilt once. Of course thats why I sold it. It mainly had a problem with the OD stop working but it did get stuck in 2nd gear once and stopped working all together twice.
Its hard to tell what kind you have or diagnose your problem from my house but there is always that chance the problem with yours is something simple to fix like the linkage or filter.
72 Beetle - trashed 88 Escort EXP - dumped 92 Talon - sold 97 Eclipse RS - still own 99 Eclipse GST - still tearing up the asphalt
Southern |
