Old 03-25-2005, 07:08 AM
gunsmithmn gunsmithmn is offline
wich water pump
just inherited a 94 s10 blazer needed water pump- used the w code off from vin # the pump runs backwards-found out the motor was swaped out 3 years back- the the moter says vortec on the cpi. any way to figure out this motor with out pulling engine for motor #- or what water pump do i need to look for.
thanks
Old 03-25-2005, 10:10 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: wich water pump
you are meaning it has the vortec name plate on top of the engine?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-25-2005, 02:14 PM
Re: wich water pump
yes... it says "vortec V6"
Old 03-26-2005, 03:58 AM
BlazerLT's Avatar
AF -Advisor
Re: wich water pump
no, that is on top of the valve cover.
The CPI has a vortec name plate on top of the ENGINE.
Old 03-26-2005, 06:39 AM
Re: wich water pump
yes it is on top of th engine
Old 03-26-2005, 07:50 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: wich water pump
Can you get a part # off the old pump? If so, post it and I will try to find the right pump.
Old 03-27-2005, 01:33 PM
BlazerLT's Avatar
AF -Advisor
Re: wich water pump
AC Delco Part Numbers
251-594
PUMP KIT,WAT (INCLS GASKET)(FLAT SHAPED BACK PLATE W/O PLUG
252-719
PUMP KIT,WAT ALL MAKES
Old 03-27-2005, 03:24 PM
blazee's Avatar
Problem?
Re: wich water pump
I meant the number off the pump that is in there now, he said that the replacement ran backwards. The engine might have came out of a different type of vehicle with a different belt route than blazer's have.
Or the parts place might have just given him the wrong pump. Discount Auto gave me a power steering pump for my Impala that ran backwards....it was in the wrong box.
