Got myself a 1993 4 door Metro w/ a 1.0 Suzuki. Heres what I've done to it so far:
New plugs & wires, new cap & rotor, new cat & muffler, new oxygen sensor, new fuel & air filter, oil & filter 10-40. Car ran good for a month, then about a week ago it started to hesitate when I eased onto the throttle, if I punch it, it accelerates fine. Car is unsteady at low speeds,and runs smooth above 25 MPH, I'm thinking fuel regulator or TBI injector. How fine a spray comes out of the injctor? I see some fuel splash when the engine is idleing. Please help me get rid of this uneasy feeling... you know, the feeling you get when your in your mom's car and she's driving. Last edited by memetro; 03-26-2005 at 03:41 AM. |
Re: Acceleration Hesitation
my guess would be the tbi. ive only worked with my 2 barrel carb on my jeep and if it drips or squirts it hesistates and runs rough. it should be a very fine mist. little bit less that cleaning spray bottle.
This problem may be your throttle position sensor. There have been many posts talking about the symptoms a bad TPS can bring on. Take a look and see if they sound anywhere close...
I am not familiar with the spare fuse method for setting timing. Could you describe how that is done?
run a can of injector cleaner through the tank but it doesn't sound to me like its the injector. i would be more likely to suspect the TPS or Map sensor located on firewall. might put fuse back in the fuse box and see if your getting any codes. can also unplug the wire going to TPS and take car for a quick test drive and see if it still has same problem then repeat with MAP sensor unplugged. if it does turn out to be either of these i do have some spares
Re: Re: Acceleration Hesitation
