Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-24-2005, 11:05 PM
Dareck Dareck is offline
Ball Joint Question
I want to change my 85 caprice from the small bolt pattern to the large bolt pattern. I know I need the rotors and calipers, as well as the spindles. My question is, are the a - arms the same as well as the ball joints between the small and large bolt patterns?
Old 03-25-2005, 05:15 AM
CD Smalley CD Smalley is offline
Re: Ball Joint Question
Most are. If you make sure you get pre-95 spindles you will be fine with your original a-arms. Sometime during 95 they changed to a larger ball joint on the b-bodies.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
