Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 03-24-2005, 08:10 PM
eappiah eappiah is offline
Location and Numbers of Oxygen Sensor
How many Oxygen sensor/s do 1994 Bonneville, 3.8L SE has?
And where are they located. I found one at the back of the engine block on the exhaust line leading to the catalytic converter.
Thank you
Old 03-25-2005, 10:53 AM
BIG-L's Avatar
BIG-L BIG-L is offline
Re: Location and Numbers of Oxygen Sensor
Thank you
1994 Bonneville 3.8L SE only has 1 O2 sensor and that is located in the rear exhaust manifold.If you are wanting to replace it,only use an AC-Delco as Ive seen other's have problem's with the Bosch after a few thousand miles.Part # for an AC-Delco O2 is AFS75 or GM part # 25312184 and you can find them new on Ebay from time to time for about 30/40 bucks or you can get it from www.gmpartsdirect.com for $45.49 shipped VS dealer list is $75.09.You will also need an O2 socket to replace the sensor and dont forget to buy some PB Penetrating Catalyst that will aide in the removal of the O2.
~Larry~
ClubGP Member 6530
Since 2001
Old 03-25-2005, 11:46 AM
Thank you
