Old 03-24-2005, 07:20 PM
anthony90si anthony90si is offline
front alignment
hi guys my car has a bad front alignment. i don't really feel like bringing it to a garage till i change my suspension in a few weeks.then i will get it done properly. so my question is to align the front do i have to unbolt the tie rod from the knucle.
thanks
stock b18a1 14.97 @ 92 mph
Old 03-24-2005, 07:38 PM
DTangent DTangent is offline
Re: front alignment
You can't adjust camber or caster on these cars. Only toe. Toe on the front requires adjusting the tie-rod. Rear is adjusted via comp arm.
Old 03-24-2005, 07:58 PM
Re: front alignment
i know that but how. by simply disconecting the tie rod. and threading it in or out?
Old 03-25-2005, 02:01 AM
honda_luvr_2000 honda_luvr_2000 is offline
Re: Re: front alignment
yes u can adjust the caster.
u don't disconnect the tie-rod end, u just loosen the locking nut and then twist the inner tie-rod to adjust the toe. then tighten the locking nut.
Old 03-25-2005, 08:02 AM
Re: Re: Re: front alignment
Well, I'd love to hear how.
Old 03-25-2005, 09:03 AM
Re: front alignment
ok to make things more clear.. the outer tie rod bolts up near the wheel. and where does the iner tie rod bolt up to.. the rack and pinion??
