Old 03-24-2005, 06:16 PM
KSAV8TOR KSAV8TOR is offline
Angry Mirror Fell Out!
I have a 1991 Silverado and the mirror fell out of the housing on the driver side,it was glued in with a silicone glue,the "stealer" said I have to buy a whole new chrome housing for 65.00..any others fixes that I might do?
The mirror fell out while driving and broke all over so I don't have it anymore...would a glass company be able to put another one in?
Old 03-24-2005, 06:25 PM
TaNK_Em's Avatar
TaNK_Em TaNK_Em is offline
Send a message via AIM to TaNK_Em Send a message via MSN to TaNK_Em Send a message via Yahoo to TaNK_Em
Re: Mirror Fell Out!
Im pretty sure I have seen something at the autoparts store that replaces your orginal mirror and not the houseing. Check out your local murays or autozone.
- Kevin
May God have mercy upon my enemies, because I won't.
- General George Patton Jr
Old 03-24-2005, 08:09 PM
J-Ri's Avatar
J-Ri J-Ri is offline
The Advance Auto where I'm at has just the glass. Use whatever glue you decide is best, then run a bead around the glass after the glue has dried. It's barely noticable, and will keep the elements off the glue.
I believe the glass replacements are for the older style trucks. They are VERY close to fitting the newer ones, but slight reshaping of the metal will probably be required, it was on my grandpa's 91.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-24-2005, 08:23 PM
chvyguy chvyguy is offline
if your handy with a glass cutter which can be picked up at local hardware store. you can just cut you a piece from any replacement glass of the same type
Old 03-24-2005, 08:29 PM
Wheeler88's Avatar
Wheeler88 Wheeler88 is offline
I smashed my mirror backing out of my driveway, the mirror frame barely bumped the garage support pole. I stopped and decided well the mirror was out of adjustment anyway and will just get pushed back a little. It worked and it shattered the glass too.
AutoZone has replacement glass or at least they use to.
88' Chevy K1500 Silverado
350 V8 5.7
Original Owner
77,000 miles
2nd tranny
Peeling Paint - Defective Factory Paint
235/85/16 BFG MT
Old 03-25-2005, 06:55 AM
clampjockey clampjockey is offline
any good glass place should be able to cut you one. i got two of them cut and installed for like $20. different kind of mirror tho; not one that shows objects smaller than they actually are.
Old 03-25-2005, 09:27 AM
DickyDoo DickyDoo is offline
you can purchase just the glass part from any windshield repair shop with out having to cut glass or special tools.place silicone on back and apply to the housing.use tape to hold in place for several hours until dry. this is really easy.you can also order the mirror part from Rockauto.com
Old 03-25-2005, 10:04 AM
Thanks guys for the replys!
Can you believe the "STEALER" wanted 48.40 for just the mirror glass!
Autozone has one for 7.25...
Thanks again!
