Old 03-24-2005, 05:47 PM
phatfigga03 phatfigga03 is offline
Rear suspension help
Hey everyone, my ride in my 88 CRX Si is quite bumpy in the back. When I hit speed bumps its really bad only in the back, and also when Im turning or anything else really I hear grinding/other bad noises coming from the rear. So I would like to know what all I need to purchase to completley re-do my entire rear suspention. Im not looking for anything high class or fancy. Just something for a nice/smooth ride.
Thanks. And pix of the upcoming rust progress will be up soon.
Old 03-24-2005, 10:28 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
Re: Rear suspension help
might be your wheel bearing, try lifting the car and shake the wheel in and out if its loose it might be u'r bearings, other than that try parts at a junk yard.
Old 03-25-2005, 01:40 AM
honda_luvr_2000 honda_luvr_2000 is offline
complete bushing set for the rear; two compensator arm bushings, two upper compensator arm bushings, two rear control arm bushings, one rear strut lower bushing, one trailing arm bushing, new strut, new spring, new upper spring seat rubber cushion. multiplied by two to cover both sides.
as for all the noises, could be a blown out bushing, cracked or broken spring, bent compensator arm or trailing arm, or as was mentioned bad wheel bearing.
Old 03-25-2005, 01:51 AM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Lets start with what you have - how far are you lowered, what kind of lowering kit do you have, and do you have a camber kit, and what size of wheels. I know on my car, I've got 96-00 rear struts and my tire will bottom out inside the wheel well sometimes when I corner really hard causing a rubbing noise - if you are lowered a lot, you might be hearing that. Also, that would cause you ride to be really bouncey and you it's really hard in the back on speed bumps.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 03-25-2005, 05:45 PM
wow, thats a lot of stuff HONDA LUVR. Thanks for the list. I was looking for some of it on ebay and couldnt find much of it on there. Is there any good HONDA sites that sell all of that? I have looked at other ones but they only have this and that, Im looking for someone to have them all. Also 4G4D, my car is completley stock right now- no loweing kits, no bigger wheels/tires etc.
Old 03-25-2005, 11:22 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
hmm my rear suspension makes a clunking noise sometimes when going over a hard bump, it kind of jumps up for a sec
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 03-25-2005, 11:37 PM
4G4D Store's Avatar
Ya - if it's stock you probably have some bushings gone out, maybe your struts too. I can't remember if the rear arms have a lower ball joint, if they do, could be that also.
Old 03-26-2005, 09:07 AM
icE_x's Avatar
ok i did a search for some decent stock-like struts, and here's some i found
http://www.monroe.com/catalog_lookup...&QU=1&LST=1090
I'm guessing i'd get the AK70 kit also that have the bushings. And i'd replace the front and back, since they all have about 208,000 miles on them i think they need replacing lol
Old 03-26-2005, 09:37 AM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
just rember the 88 has different rear suspention than all the other years (88, 89-91) it has passive or something like that, i dont have an 88 so i cant really tell you anything useful
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
