Old 03-24-2005, 03:09 PM
mystic37601's Avatar
mystic37601 mystic37601 is offline
Question Water in trunk?
There is a puddle of water in my trunk, soaking everything inside. It doesn't appear to be coming from the hatch, but somehow from underneath. I'm no car expert & I haven't had it looked @ yet, but I wanted to check here 2 see if anyone had any ideas how the water could be getting there...thanks!
Old 03-24-2005, 03:36 PM
lostmypicks lostmypicks is offline
Re: Water in trunk?
all I can say is lots of duck tape lol
sorry dont know but that sucks
Old 03-24-2005, 03:53 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Water in trunk?
there is a drain plug for the water where the weatherstripping on the hatch contacts the car when you shut it. it's a small tube that drains down out of the car and sometimes those are plugged/kinked and cause that water to drip inside because it has nowhere to go. it's underneath the plastic and runs along the inner tire well.
95 Talon TSI AWD
97 Eclipse GST
Old 03-24-2005, 07:51 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Water in trunk?
if its a 1g the problem could be your rear window seal. i've fixed it on 2 of mine. when it rained it would leak water into the rear plastic on the underside of the hatch then when i opened it it poured out either end.
to fix it:
just pop the outside weatherstripping off the bottom of the back window and pack the window seam with silicone. let it dry for a couple hours then put the weatherstripping back on
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
