Old 03-24-2005, 03:00 PM
loco69boyz loco69boyz is offline
Unhappy HELP: What should i do
My 99 eclipse gs just got a knocking noise in the engine, i replaced all the belts, water pump, oil pump, brand new complete head(cams,lifters,valves,rockers, whatever else comes in the head) and i still have this knocking noise. I think its a rod knocking or something. Should i sell it as it is and buy a new car or get it fix.
Old 03-24-2005, 08:34 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: HELP: What should i do
if you like your car, get it fixed. have the bottom end re-built. pistons, bearings, gaskets, oil pump, water pump, etc.
if you want a faster car, sell it and buy a turbo while you can.
95 Talon TSI AWD
97 Eclipse GST
Old 03-24-2005, 11:43 PM
ted_ex's Avatar
ted_ex ted_ex is offline
Find out where the noise is coming from on the engine. If it only started when you put a new head on, it could be the lash adjusters clattering until they fill with oil. It's a pretty damn loud noise but it goes away after a little while. If it's coming from the bottom of the car it could be a spun bearing or rod knock.
I'm>everything
Old 03-25-2005, 12:36 AM
i think he got a new head and thought it would eliminate the problem. pull off the oil pan and the rod caps and check the rod bearings.
95 Talon TSI AWD
97 Eclipse GST
Old 03-25-2005, 12:45 PM
Yeah i had the knocking noise before i put the new head on. It sounds like the noise is coming from the top right of the valve cover put when you rev it the noise gets a little louder and sounds like it switches and the sound comes from the middle of the engine. When i dropped the oil pan to put the new oil pump in...i found 2 shiny tiny metal chips stuck to the magnet in my oil pan. It was the size of a pen tip but flat. I know that aint good.
Old 03-25-2005, 12:49 PM
Selling it
If i do sell it how much yall think i should sale it for. I have black widow front and a drift front bumper in the garage, turbo spoiler, oz racing rims, carbon fiber hood, Tenzo-r lowering springs,greddy headers, obx catback, 3 MTX 10's with 500 watt amp, altezza tails with new belts including timing, new oil pump-water pump-and ported head with new internals in the head?
Old 03-25-2005, 09:34 PM
why not just fix it and keep the car? unless you plan on going turbo, i would keep it since you won't get your moneys worth of the mods and if you're going to buy another one, you'll just be spending that again anyways.
95 Talon TSI AWD
97 Eclipse GST
