Old 03-24-2005, 12:19 PM
lionelkirk2004 lionelkirk2004 is offline
Send a message via Yahoo to lionelkirk2004
Passenger Door Problem?????
A while back someone slammed a seatbelt in the pass. door really hard. Now the door is closing, but not the right way, its closing to where the door is alittle to high and is letting in water. Can you please tell me how to fix it? The tools and stuff that I will need?
Also, the hinges are fine, I think that the latcher thing that on the side of the door is part of the problem. Please help!!!
Old 03-24-2005, 12:35 PM
tightwad tightwad is offline
Re: Passenger Door Problem?????
Does the latch inset into the door have adjustment bolts? can you verify that as the door closes, the latch is causing it to slide upward?
One way to see where it is hitting is to paint the striker bolt with white-out or a similar substance. Then slowley close the door until it makes contact (but not shut) Do this to see where on the striker bolt the latch is hitting. It should be in the middle, not at the bottom.
Old 03-24-2005, 12:44 PM
yeah, on the side but you have to have a tool that has lot of ridges on it. yes, I can verify that.
Old 03-24-2005, 04:04 PM
That would be a torx socket. they cost about $15 for a set of 6, or you can buy the one size.
