Old 03-24-2005, 02:06 AM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
Wheel bearing
When I went to get an alignment a few months ago the alignment shop told me that I might as well not align the fount end because the passenger side wheel bearing is bad and it will just get unaligned in a few days.
After a bolt fell out that held my control arm to my suspension came undone(WTF) I put in a new half-shaft and new control arm and now when I turn right it clicks loud and kind of jumps a little bit. If I turn left its just fine.
Two questions. First: How hard is it to change a wheel bearing?
Second: Is that jumping from the wheel bearing or shitty alignment?
Blowing motors since 2005.
1995 Eclipse GS 5 Speed(White)
1995 Eclipse GSX 5 Speed(Silver)
Need a file hosted? IM me.
For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.
Originally Posted by EclipseRST
Thats like fucking glitter...
Old 03-24-2005, 07:20 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Wheel bearing
Did you do the control arm or did you have the dealer do it under the recall? If you did it yourself you can make the dealer reimburse you for the parts.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 03-24-2005, 08:18 AM
CBURKE's Avatar
CBURKE CBURKE is offline
Re: Wheel bearing
Well for the wheel baring i know on hondas you have to press them in and out. If you don't have access to a press then it may be cheeper to take the hub asem and take it down to a shop with the baring have them press the old one out and out the new one in. They will only charge you like 20 to 30$ for the job.
98 MITSU GST, 1990 TURBO MOTOR
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 03-24-2005, 09:28 AM
Jroc97 Jroc97 is offline
Re: Re: Wheel bearing
How do i go about getting this done. Do I need to bring them any paperwork? What do I say when I get their
97spyderGS
Old 03-24-2005, 12:40 PM
Re: Re: Re: Wheel bearing
I would also like to know.
Old 03-24-2005, 01:09 PM
Re: Wheel bearing
There is a ball joint and lower control arm recall on almost all of the 2g's. Check www.alldata.com for your specific details. Anyway, you need to show them proof of payment for the work. Or a receipt for the purchase of the parts, if you did the work yourself.
When you get there tell them that you had to replace the lower ball joints and the lower control arm and you want reimbursed because of the recall. Give them your paperwork and they will send you a check.
Oh, and I'll take 10%......
1997 Spyder GS-T
5-Speed
Old 03-24-2005, 05:22 PM
Re: Wheel bearing
Too bad the closest mitsu dealer is like 4 hours away.
