Old 03-24-2005, 01:06 AM
tawn23 tawn23 is offline
2001 Cavalier Back End Noise
I have a 2001 cavalier. The back end is making this loud banging noise when I'm driving over bumpy road or train tracks. It sounds like it's coming from near the trunk. A friend of mine said something about a bar, but he didn't know what it was called. Can anyone shed some light? Thanks!
Old 03-24-2005, 12:38 PM
big dude1 big dude1 is offline
...Do you have anything in your trunk? i keep a tool box in my trunk for emergencies, and every time i go over a bump it makes a lotta noise... he might be referring to a sway bar...
i love my new sound system... Alpine type R 12" sub, Alpine deck, and MTX amp
2001 Z24 cavi, and it owns
Old 03-30-2005, 05:58 AM
franmosso franmosso is offline
My 97 does the same thing. I have not been able to locate its origin yet. Could be the muffler straps are letting go allowing the muffler to hit the frame. Take a look.
Old 03-30-2005, 03:22 PM
punltildeath05 punltildeath05 is offline
Lightbulb I had the same thing
hey i have a 96 cavi. it had the worst noise ever in the back kinda like popcorn. its was just a washer that conects the struts to the body. i replaced my struts and made sure that bolts was tighten down so the washer doesn't move...
Old 04-04-2005, 06:52 AM
Ryan066 Ryan066 is offline
Yea... Its the rear strut mounts...
you can replace just the mounts for 100 taxes in CDN if u do it yourself but u have to compress the spring..
if you take it to a shop they will want to replace ur mounts and struts...
I got away with just replacing the mounts and it was all good.
Old 04-05-2005, 06:39 AM
homerr homerr is offline
Re: 2001 Cavalier Back End Noise
I have a 2001 Sunfirewith the same noise. I just backup and bump the brakes and the noise is there. Strut mounts as I was told. You would think be now they would realize this and do a recall.
Old 04-06-2005, 06:08 AM
Curtis20 Curtis20 is offline
Send a message via MSN to Curtis20
Re: Re: 2001 Cavalier Back End Noise
Same problem here i have 00 sunfire se and in reverse ( sometimes forward) to when im driving slow and hit the brakes hard enough a big CLUNCH noise comes and my back tire drags and the suspension goes way down on one side. and often when im driving i dont really have abs anymore and sometimes i do , i can hit the brakes at a stop sign and the tires lock and othere times they dont????
Old 04-06-2005, 06:35 AM
That sounds to me that you have a leak in your wheel cylinder and the fluid is going on to your drum. The fluid is sticky and will cause your wheel to lock at slow speeds. The same think I have had on my Sunbird. Can be dangerous at high speeds if you have to slam on your brakes.
Homerr
Old 04-07-2005, 05:17 PM
Yeah... curtis that sounds defently like a brake problem and maybe even the strut mounts too..
idd jack it up... put a pry bar underneath the tire and pry up... if they is any play u can see/hear at the mount id replace it..
also inspect your stuts to see if there are leaking any oil and do the bounce test... if it bounces more then a couple times the struts are bad.
then take off your drum and take a look if the wheel cylinder is seazed or anything is damaged. then adjust the brakes to see if they are over tightened and test it out... THEN if it still locks up Bleed the line... if there are any grease or contaminents in the fluid it can cause the wheel to lock up... you only need to bleed the line at the tire locking up
Old 04-11-2005, 06:09 AM
allright that stuff will be done very soon thx alot for the advice and ill let yeah know how it turns out
Old 06-22-2005, 02:56 PM
elkyone elkyone is offline
Send a message via AIM to elkyone
we have 2004 Cavalier and it sounded like a bumping under the back seat and I believe it was a bushing that wasn't there.. I will check the repair order
