Old 03-24-2005, 12:50 AM
Twyztidmind Twyztidmind is offline
Send a message via AIM to Twyztidmind
HELP!! SWAPING A B18 LS into Civic DX
Hey guys, i have been searching the internet for ever now. I need to know how to wire up the b18 in to my 89 civic DX hatch. I have a 90 integra parts car with 5 speed. But i just bought a new engine out of a 94 integra. What kind of wiring am i going to have to do to make this all work??
Any help will be usefull. I already have mounts, shift linkage, ect.
Old 03-24-2005, 02:13 AM
Hybrid1990crx's Avatar
Re: HELP!! SWAPING A B18 LS into Civic DX
you're gonna have to wire over to MPFI and get a resistor box from a mpfi car. Ami's website has a write up on it www.4thgenerationcivic.com, and www.fourthgenhatch.com has I write up to, but im not sure if his page is up anymore.
Old 03-24-2005, 06:42 PM
Can i cut the plugs off the harness on the car and the engine and match them by color??
Old 03-24-2005, 06:51 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
why not use the 90 teg motor to swap into you civic
Team Lonely Drivers
Old 03-25-2005, 01:10 AM
I would just use the 90 integra engine but it is blown. So i have a 94 engine.
Old 03-25-2005, 01:55 AM
yeah do the mpfi swap, swap the dist and intake mani over to the 94 motor and plug in the pr4 ecu and your all set as far as wiring. you might have some trouble with the dist
Team Lonely Drivers
Old 03-25-2005, 12:10 PM
so i take the dist. and the intake manifold off the 90 and put it on the 94?
Old 03-25-2005, 01:41 PM
89hatcher's Avatar
89hatcher 89hatcher is offline
Send a message via AIM to 89hatcher
Re: Re: HELP!! SWAPING A B18 LS into Civic DX
yeah and you will need the 90 teg ecu and i think that everything will be plug and play once you convert it to MPFI....
Old 03-25-2005, 02:34 PM
since its a obd1 motor, you might have trouble with the dist. try and swap the dist first and see how it works out before you do anything else.
Team Lonely Drivers
Old 03-26-2005, 01:35 AM
OK thanks, do i use the integra harness or the civic harness to connect to the engine?
