Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 03-23-2005, 10:02 PM
Smokee's Avatar
Smokee Smokee is offline
Fuel gauge misreads
Ok, reading all the previous posts has answered most of my questions about my 97 Jimmy. But not all....recently my fuel consumption went through the roof. At the same time, my fuel gauge stopped reading full even though it was full to the brim. When I fill up, it reads ¾ full. As far as the gas mileage goes, I suspect the CPI unit is leaking. But I can't figger out the gauge thing. Engine light is always on. PO300 code (random misfire engine cold at 0 mph) and I get a P1870 (tranny slipping). Any help to the above would be greatly appreciated.
Old 03-24-2005, 08:01 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Fuel gauge misreads
For the gauge, it's the sending unit that's bad/not sending right... For the p0300, that could be caused by your fuel injector dumping fuel (You have CSFI, NOT CPI), but it is more likely caused by the need of a tune up (cap, rotor, plugs, wires) or your coil..., the tranny slipping could be because of a bad valve body or a bad ignition switch (look to the ignition switch first)
Old 03-24-2005, 11:51 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
1997 ignition switch causes many problems from sender problems to tranny codes and engine performance failures.
Tune up the engine completely.
Replace the ignition switch.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-28-2005, 03:35 PM
Smokee's Avatar
Re: Re: Fuel gauge misreads
Thanks for the advice. You guys are great. I can't believe how many little problems were solved by simply replacing the ignition switch. And yeah, them little torx screws at the end were real bastages. Thanks again.
Old 03-28-2005, 05:27 PM
BlazerLT's Avatar
AF -Advisor
Sweet, glad it worked for you.
So everything is perfectly normal now?
Old 03-28-2005, 07:59 PM
Smokee's Avatar
Re: Re: Re: Fuel gauge misreads
Actually, it fixed everything except the fuel gauge problem. But the rough idle, misfiring and excessive fuel consumption all seem to be gone. Also, my SES light is not on for the first time in months. I am doing a major tune up including fuel filter tomorrow. If that don't fix it, I'll have my fuel pressure checked and go from there.
