Old 03-23-2005, 09:50 PM
tooused tooused is offline
electrical/fule delivery problem
my 87 s-10 blazer died on me, and once i got it towed home, i tried to pinpoint the problem. so, the fuel pump doesn't run upon setting the key/ignition to run (it shoud run a few seconds before shutting off in run position prior to twisting key to start). also, the fuse for horn/dm keeps blowing. now, i know the horn has nothing to do with the fuel delivery, and the dome light shouldn't either (true?). but what hidden connection am i missing here? there's something funny going on, and the 20 amp fuse in this slot so blowing upon replacement, and the truck won't start or go (fuel pump not running). i don't want to have to remove 13 gallons of gas, drop the tank, and check/replace the fuel pump if there's some other short circuit i could be dealing with.
any advice or knowledge about this scenario out there?
thanks-
henderson
Old 03-24-2005, 01:18 AM
OverBoardProject OverBoardProject is offline
Banned
Re: electrical/fule delivery problem
no sugestions except if you have to pull the tank to replace the fuel pump it might be a good time to drop in a 20 gallon
