Old 03-23-2005, 09:28 PM
Eric0902 Eric0902 is offline
1994 S-10 2.2 liter, engine surges at cruise, slight decel
I am new to this forum to begin, and I am a Chevrolet Technician. 2 co-workers, my Service Manager, and I are stumped... I recently aquired this vehicle for a low price because the Clinder Head was cracked. I replaced the head the day I bought it, also plugs, wires, t-stat, air filter, PCV valve,fuel filter, and performed an induction, and injector clean. We are stumped because, at a cruise of any speed with no load on the engine, it surges real bad. I have taken numerous "snapshots" with the scan tool, and analyzed all the engine data, and all is within specs. Does anyone have any ideas ? I am almost out of options...
Old 03-24-2005, 06:58 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: 1994 S-10 2.2 liter, engine surges at cruise, slight decel
did you look at the oil? and what does the exhaust smell like?
Old 03-24-2005, 01:31 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Fuel pump culd be not putting out the right pressure.
Check fuel pressure.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-24-2005, 08:38 PM
Yes, I have looked at the oil, not milky, and looks as clean as the day I put it in, just 6 days ago. The exhaust has no sweet smell, no smoke (white, black, or blue), smells like exhaust...
Old 03-25-2005, 01:54 AM
BlazerLT's Avatar
AF -Advisor
Again, check fuel pressure.
Old 03-26-2005, 10:38 AM
I Have checked fuel pressure, Key on it goes to 45 PSI, then when the pump powers down, it goes to 39-42 PSI. I have also ran an Injector Balance test, and replaced 1 Injector that was flowing too high, and the truck still surges...
Old 03-27-2005, 01:51 PM
BlazerLT's Avatar
AF -Advisor
Fuel pressure is perfect really.
I would check to see if the cat is plugged or if the pump is overheating.
Also, are these things happening when the air conditioning or defrost is on?
Also, when you are saying it is surging in when cruising, are you stating that you are using the cruise control when this happens?
Have you ever removed and cleaned the IAC and the hole it inserts into?
Old 03-27-2005, 05:39 PM
Smile
Well, i figured it out yesterday... i will reply to Blazers last post first. Fuel pressure is good, IAC has been removed cleaned, then replaced when it still "surged", the vehicle does not have cruise or a/c, and the HVAC control was in the "off" position. Well, to put you all at ease, and make me a very plaesed owner, i fixed the problem yesterday. The EGR valve was bad, so I replaced that, and it runs like it is brand new...
Old 03-27-2005, 05:50 PM
didnt try to clean it first?
Old 03-27-2005, 08:27 PM
BlazerLT's Avatar
AF -Advisor
Yea, I would have cleaned it first, but hey, if it fixes the problem, enjoy your truck.
