Old 03-23-2005, 08:34 PM
BlazinUP BlazinUP is offline
changing a 93 cpi spider unit?
anyone know of a walkthrough for changing the cpi unit on a 4.3?
iv seen them for other things......like heater core.....any for cpi?
Old 03-23-2005, 09:02 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: changing a 93 cpi spider unit?
93 should be tbi.
Old 03-23-2005, 09:33 PM
umm that may be so,,,,in some cases,., but mine is a 93 vortec cpi...........
Old 03-24-2005, 07:52 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
CPI was 92-95 for the record...
Simply remove the VORTEC cover (T25 torx), the throtle bracket (2 8mm bolts) Disconnect all the sensor wires, the 3/8th vac hose at the brake booster and the 1/4 vac hose on the back of the upper plenum. Remove all the nuts/bolts around the outside of the plenum (9 10mm) and set aside.
Lift off plenum. You might have to yank a little hard if it's the oem gasket. Set aside. Take 6 paper towels, roll into balls and stuff them into the intake ports. (This prevents dropping anything down them) Squeeze the release on the injector harness and lift straight up.
Remove the U-clip on the driver's side of the injector and slowly pull the lines out.
Squeeze the side tabs of each poppet and pull firmly out.
Lift injector out. Install in reverse...
Make sure you scrape the surface of the upper and lower plenum mating surfaces clean for the new gasket.
I also reccomend replacing the nut kit while you're in there. It's not expensive and it will make it so you don't have to do in there again if the lines crack...
Old 03-24-2005, 01:29 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Here is some information:
http://www.s-seriesforum.com/forum/s...threadid=34668
You will have to register, but there are photos and diagrams to help you out.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-24-2005, 10:51 PM
kool thanks guys
