Installing a BOV
I need to know how to install a BOV and also a BOOST GAUGE. I own an 86 Integra. Thanks in advance.
Re: Installing a BOV
the bov you install into the intake piping assuming your turbo is intercooled it's the piping that leads from the intercooler into the intake manifold and then run the a vacuum line from the bov to the intake, and the boost gauge you simply run the vacuum line to the manifold and wire the positive wire into the parking lamps or headlamps switch and the ground wire to a good ground. As far as the bov goes if the intake piping does not have a fitting already welding into the piping you'll need to cut out a section of the piping and weld in a fitting for the bov or weld the bov directly to the intake piping.
Built and boosted... "I feel the need.... the need for speed!" http://www.automotiveforums.com/img.php?313283teggie2.JPG |
BOV flange on the charge pipe. vac line from boost gauge to vac source.
99 [email protected] psi si- I voted for the Terminator for Gov. 95 HB- B16a2- SC34@12psi WTB: USDM B16a2 or B16a3 complete short block. pm is the key. FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me. |
so does it realy matter what vaccum i use off of the intake manifold
just T it to any other vac line other than the wastegate.
thanks
