Old 03-23-2005, 07:36 PM
papawolfe papawolfe is offline
Question quit charging,blowing in-line fuse
i have a 1997 ford powerstroke it quit charging and blew the inline fuse to starter relay i replace the starter the alternater,the glow plug relay,glow plugs i check out the wiring with ohm meter ,i'm stumped what could be the problem. thanks to anyone who can help me.
Old 03-23-2005, 07:48 PM
mustangmike351c mustangmike351c is offline
take the fuse out and check for short to ground from there
Old 03-24-2005, 06:04 PM
Re: quit charging,blowing in-line fuse
i did pull the fuse also took the harness off that the in-line fuse was attach to and check for broken wires and burn ones and it looks good it's the harness that goes to the alternater and a/c
Old 03-24-2005, 06:40 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Mustangmike351c has a good point. Pull fuse and use an ohmmeter to check from each side of fuse holder to ground. Since this is a power circuit, there should be an infinity reading(no movement on an analog meter or OL reading on a digital readout meter.) If there is continuity to ground, you need to unhook wires at each connection until the continuity disappears. Then look at that section of wires for short to ground. If you unhook the alternator and continuity goes away, the alternator is shorted internally. Hope this helps some.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-24-2005, 06:48 PM
Smile Re: Re: quit charging,blowing in-line fuse
thanks i will try that to see what happens it will be acouple of days before ido it
