Go Back   Automotive Forums Car Chat > Kia > Sephia
Old 03-23-2005, 06:43 PM
JCAUTOWRKS JCAUTOWRKS is offline
Not Shifting
have 1998 kia sophia transmission stays in second gear at all times, but will shift manually fine. any ideas
Old 03-24-2005, 12:16 AM
cbeck cbeck is offline
Re: Not Shifting
I know next to nothing about a/t, but I think there is a solenoid for each gear, perhaps that has gone out. I'm not sure what else could go wrong.
I'm guessing you already checked the fluid level?
I'm not a mechanic, I'm the guy people bring their car too when they don't run. I usually scratch my head and tap on stuff, then call the dealer to see if they can help me find the carburetor.
Old 03-24-2005, 10:19 PM
derrty_ent_derrty derrty_ent_derrty is offline
Banned
Re: Not Shifting
od light on? if so its speed sensor. other than that im clueless
Old 03-25-2005, 01:36 AM
Re: Not Shifting
d_e_d brings up a decent point, as driving around with the od off is the sort of thing I would do...
I checked to see that there are three soloniods, and they all are "active" for third and fourth gear.
so consideri9ng you can shift manually, i would put order of likelyness
1-low fluid
2-OD switch malfunction (ok, but this would only cause a problem in 4th gear maybe?)
3-speed sensor malfunction (from my understanding, i think this would affect the spedometer as well, but maybe no necesarily)
4-turbine speed sensor malfunction
5-solenoid valve (last as i think if this didn't work the manual shift wouldn't either)
Checking your DTC's might give some more insight as I'm not sure if the other various sensorswould cause an "auto" malfunction while still allowing manual shift...
If your planning on tackleing this on your own, good luck! (i should be able to check what the apt resistances of the different sensors should be if you do give it a go)
Old 03-25-2005, 09:04 AM
thissucks thissucks is offline
Banned
Re: Not Shifting
the speed sensor makes the speedo go nuts and the car runs very oddly. it will rev when started and slowly descend down to idle. its a high rev too. maybe even runs 2500 to 3 grand
