Go Back   Automotive Forums Car Chat > Honda > Legend | RL
Old 03-23-2005, 06:08 PM
bpatt bpatt is offline
RL ABS Code access
Do I need a special tool to access the ABS codes? Are there pins I can short at the test port to activate the blinky light codes. I have the codes, just need to get the light to blink them
Old 03-24-2005, 09:20 AM
phantastic1 phantastic1 is offline
Re: RL ABS Code access
a paperclip would do....you didn't mention what year your car is....but i think this should apply pretty much to all rl's. there should be a 2 pin connector below the glove box (maybe easier to see if you stick your head under to see). it's a 2 pin connector thats hooked up to nothing...slide it out of the holder and jump the 2 pins w/ a paperclip. then turn the ignition to II, not run. now count the flashes of the abs light.
