Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-23-2005, 05:59 PM
squaty1218 squaty1218 is offline
Question Fuel Pressure Adjustments
I have a 95' non-turbo Eclipse (420a). I put Stage 4 Crane Cams in and up the compression from 9.6:1 to 10.5:1 + other mods. ( underdrive crankpulley, adj. cam gears, knife edged & lightened crankshaft, lightened flywheel, ported+polished intake man. , Ferrea valves, springs, +retainers, Iridium spark plugs, 8.5mm wires, 4-1 headers+cat-back exhaust, venom injectors, and an AEM adj. fuel regulator)
How much fuel pressure will work for this setup without damaging anything? And if there is anything I have overlooked in building this motor please don't hasitate to suggest it. Thanx.
Old 03-23-2005, 09:21 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Fuel Pressure Adjustments
the bottom end. rods and pistons especially.
you gotta lay the foundation before you can start building your house
95 Talon TSI AWD
97 Eclipse GST
