Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 03-23-2005, 03:56 PM
limewire limewire is offline
Send a message via MSN to limewire
Oil Cooler Lines
Hi again. I recently discovered my oil lines are leaking and discovered a post about pricing but has anyone done this job themselves? Any tips would be great.
Old 03-23-2005, 10:05 PM
ChicoR101 ChicoR101 is offline
Re: Oil Cooler Lines
Make sure that it is actually the lines that are leaking. If it is the set that go into the rad, remove the clips and pull the lines out. You may have to use a small pry bar or screwdriver to remove them. Inside the fittings that thread into the rad there is an o-ring. It may be worn and leaking from there, running down the line and making it appear that the line is leaking. This job is easiest to do if you remove the air filter box.
The other possibility is that the lines are leaking where the rubber hose is crimped to the pipe. Apparently this is a known defect, but good luck getting any warranty.
I have replaced both sets of lines on my Jimmy at a cost of approx. $150.00 each set (in Canada). My front lines started leaking again about 1 year after I replaced them. Just a couple of days ago, I repaired the leaking lines. I wasn't going to pay another $150.00, so I had two 1/2" hydraulic lines made to match the length of the rubber lines. I used a small pipe cutter and cut off the rubber hose sections. I then installed the hydraulic lines with ferrule type crimp fittings. It is a little bit of work to get the pipes lined up properly to go back into the rad, but ends up being about $50 - $60 (Canadian) to repair, depending on where you get the parts. This will definitely last longer than the stock junk! If it does start to leak again, then the fix is as simple as either tightening the crimp fitting a little, or replacing just a section of hydraulic line.
Hope this helps.
Old 03-24-2005, 11:54 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Wher are they leaking?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-25-2005, 12:17 PM
oil cooler lines
Well I was under the lady today and all I came up with is that the line the runs to the transmission is covered in oil can not really see where it is leaking from. Should I just replace both lines? Which leads to my next question, can these lines be bought at Napa or Partsource?Also I ran my car through the car wash and broke the rear licence plate light cover that holds the light in. Do you have to buy them at the dealer?
Thanks for the help.
Old 03-26-2005, 03:37 AM
BlazerLT's Avatar
AF -Advisor
The transmission cooler lines are leaking?
