Old 03-23-2005, 03:46 PM
M3FordBoy's Avatar
M3FordBoy M3FordBoy is offline
2007 Ford Shelby Cobra GT500 Mustang
http://media.ford.com/newsroom/featu...?release=20294
What do you guys think? I think Ford did a good job on the looks, but why can't Carroll Shelby get his own car? Putting the Cobra and GT500 together isn't a bad idea, but for SVT enthusist all there is on the outside is small Cobra symbols. And only says SVT on the motor. While you have the word Shelby real big on the back and GT500 on the rocker behind the front wheels. I guess all I'm trying to say is Shelby should make his own car and stay away from SVT stuff. Now don't think I dislike Shelby I just wish he would make his own car instead.
'91 Kawasaki Ninja 600R
Newest Toy: V&H, Stage 1 carbs
'89 Honda Accord DX
A20a1 5spd Daily Driver
'68 Ford Galaxie 500 XL
390fe C6 First Car/Project Car
See/hear the ride.
http://www.youtube.com/watch?v=rO0C-qxj6qA
Old 03-23-2005, 05:49 PM
PMDtempest's Avatar
PMDtempest PMDtempest is offline
Banned
Send a message via AIM to PMDtempest
Re: 2007 Ford Shelby Cobra GT500 Mustang
Why should shelby stay away hes basically been modifying stangs since the 60's before SVT stuff was even thought of so dont go staying shelby should stay away from SVT stuff and go build his own car "which he did twice". 5.4's arent engines that are seen in every single SVT. This thing should be sick tho with 450hp and the aggresive styling. once again shelby has produced another great car or "modified another great car"
Old 03-23-2005, 09:00 PM
M3FordBoy's Avatar
Re: Re: 2007 Ford Shelby Cobra GT500 Mustang
You stated my point realy, who's car is it SVT's or Shelby's. I think Shelby is a great guy I'm just am trying to say I think he should of made his own and called it the GT500 and SVT can still have their Cobra instead of putting the two together. Now SVT really doesn't have a Mustang of their own because most people will refer to it as the Shelby Mustang or GT500. Unless their are just going to start using SVT for the chassi and drive train only I guess it could make sense, but really SVT doesn't have a Mustang because Shelby takes them and puts his name on it. It's like the Mustang GT's that become Saleen S281's. You really don't call them GT's any more.
'89 Honda Accord DX
See/hear the ride.
Old 03-23-2005, 10:26 PM
spy604's Avatar
spy604 spy604 is offline
Send a message via AIM to spy604
who cares if SVT has a mustang or not, i know i dont. Im sure there will still be a regular production cobra soon, ford is just doing the exact same thing that they did back in the 60's, shelby had his modified gt's, and ford built their mach 1s and bosses, no one is upset about any of that
We're all living in Amerika
Amerika ist wunderbar
"So where'd you get the beauty scar, tough guy? Eatin' pineapple?" / "How ya getta scar like that from eatin' pineapple, man?"
-Scarface, TV Version
1986 Mustang GT, Black, T-Tops, Very tired 5.0
Old 03-24-2005, 08:39 AM
motorjock205's Avatar
motorjock205 motorjock205 is offline
Send a message via MSN to motorjock205
Who Cares? SVT/Shelby
Who cares anyway??? I want one of these bad boys no matter WHO makes it!!!
Forget World Peace, Visualize Using Your Turn Signals!!!
Carl W. Ervin
2008 Shelby GT CSM 08SGT0235
Old 03-24-2005, 12:35 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
The 60's GT350 and GT500 were Ford Shelby Mustang-Cobras(enough names?). Cobra is a Shelby name, why shouldn't his name be on it? SVT revived the name back in 93 or whenever the first newer cobras came out. SVT never put a lot of badging on their cars.
http://media.ford.com/newsroom/featu...?release=20297
There is a picture on that link of the top of the car so you can actually see the hood.
FYI - all the badging is taken directly from the 67-68 GT500s. The Shelby lettering on the trunk lid, the cobra in the cap between the tail lights(used to be a gas cap in the 60s, now its the truck lock i think?), the striping on the bottom obviously, the cobra tag on the front fenders(above the GT500), and the cobra in the side of the grille. They're all cues from the original GT500. Although the cobra is on the wrong side...
Old 03-26-2005, 11:53 PM
57JagXKSS 57JagXKSS is offline
Banned
Ford and Carroll Shelby renewed their partnership to produce high-performance automobiles in 2003. Read this article.
http://www.motorsportscenter.com/article_276.shtml
Old 03-26-2005, 11:58 PM
Banned
pictures of the 2007 Ford Shelby Cobra GT500
http://www.fordimages.com/gallery/th...s.php?album=53
TECHNICAL SPECIFICATIONS
BODY
Construction Unitized welded steel body, aluminum hood
ENGINE
Type V-8
Manufacturing location Romeo, Michigan
Configuration Iron Block and Aluminum Heads
Intake manifold Cast-aluminum with screw-type supercharger and air-to-water intercooler
Exhaust manifold Cast iron
Crankshaft Forged steel
Throttle body Dual 55 mm, electronic
Valvetrain DOHC, 4 valves per cylinder
Valve diameter Intake: 37.0 mm
Exhaust: 32.0 mm
Pistons Forged aluminum
Connecting rods Cracked forged steel I-beams
Ignition Coil-on-plug
Bore x stroke 3.552 x 4.165 in. / 90.22 x 105.8 mm
Displacement 330 cu. in. / 5,409 cc
Horsepower More than 450
Torque 450 lb.-ft
DRIVETRAIN
Layout Rear-wheel drive
TRANSMISSION
Standard (Type) T-56 6-speed manual
Gear ratios
1st 2.97
2nd 1.78
3rd 1.3
4th 1.0
5th .80
6th .63
Final drive 3.31
SUSPENSION
Front Reverse-L independent MacPherson strut, 34-mm tubular stabilizer bar
Rear Three-link solid axle with coil springs, Panhard rod, 24-mm solid stabilizer bar
BRAKES
Type Four wheel power disc
Front Brembo 14-inch vented and cross-drilled disc, four-piston aluminum calipers
Rear Brembo 13-inch vented and cross-drilled disc, two-piston calipers
TIRES AND WHEELS
P255/45R19 tires and 19 x 9.5-in machined aluminum wheels
EXTERIOR
Wheelbase 107.1 in.
Overall length 188 in.
Overall width 73.9 in.
Overall height 55.7 in.
Track width, front/rear 61.9 in. / 62.5 in.
Ground clearance 5.71 in.
INTERIOR
Seating capacity 4 passenger
Headroom
Front row 38.8 in.
Second Row 36.3 in.
Legroom
Front row 42.7 in.
Second row 30.3 in.
Shoulder room
Front row 55.4 in.
Second Row 45.0 in.
Hip room
Front row 53.6 in.
Second row 45.2 in.
Cargo Volume 9.7 cu. ft.
Old 03-27-2005, 07:11 PM
BullittStang's Avatar
BullittStang BullittStang is offline
Send a message via AIM to BullittStang Send a message via Yahoo to BullittStang
It's alright. I'm really dissappointed that the car doesn't have IRS. That's the only thing keeping me from purchasing one. I may just use that money and invest it ona GT40 replica and turning my 66 Fastback into a GT350 clone.
"Racing is life, anything before or after is just waiting"-Steve McQueen
Old 03-27-2005, 08:02 PM
emokid15 emokid15 is offline
i saw alot of pictures of this car. @ svtperformance.com. its bad ass man. i want 1 now lol.
1987 Ford Mustang 5.0 GT ( Stock )
Old 03-27-2005, 11:44 PM
tturnpaw's Avatar
tturnpaw tturnpaw is offline
Send a message via AIM to tturnpaw Send a message via MSN to tturnpaw
I think SVT is just the model up of the Cobra. Shelby has made so much money on modifing mustangs, so why not? Besides he makes a Series 1. And where do u think the ACR cobra came from? He knows that in the mustang business he is big, so he makes a bigger name for himself making another car for the fans. Id rather have one of his cars than a freakin SVT 2005. He also makes dodges 2, i just dont remember which ones.
1982 Mustang GT- roller motor x303 cam, GT40s, MAC/Spintech exhaust MSD ignition, Edelbrock Carb, Ford Racing roller rockers
1994 Escort 2DR LX - cone air, 3.8L throttle body, FUTURE SPI turbo swap
Cops: You can race, but Im impossible to chase!
LS WHAT?
Old 03-28-2005, 08:19 PM
Banned
great pics
http://www.rage-board.com/files/gt500/
Old 03-28-2005, 09:58 PM
Muscletang's Avatar
Muscletang Muscletang is offline
AF Premium User
I understood it that Shelby didn't have anything to do with this thing. SVT designed the whole car like they've always done but instead of calling it the "2007 SVT Cobra" they're calling it the "2007 GT-500" in rememberance of the Mustang Cobras of the '60s.
For a long time it gave me nightmares... witnessing an injustice like that... it's a constant reminder of just how unfair this world can be... I can still hear them taunting him.......
silly rabbit, tricks are for kids...
I mean, WHY COULDN'T THEY JUST GIVE HIM SOME CEREAL?
Originally Posted by Lars Ulrich
What?! Record sales are slumping? Must be from all those pirates. Can't be because we started sucking 10 years ago.
Old 04-01-2005, 03:04 AM
Banned
Carroll Shelby and Ford joined forces again back in 2003. Read this:
Old 04-03-2005, 07:00 PM
ghostx's Avatar
ghostx ghostx is offline
I love the power plant and the efforts they made to make the car more ergonomical.
With that said, I must say that I am dissapointed with the cars appearance. I know it's classic, but all the friggin badgin has got to go! If we're going to have the cobra on it we don't need the "GT 500". Shelby could've put his name in smaller letters across the back if we needed that. I never thought I'd say this, but I think Ford has come short of my expectations, and that's not an easy feat!
and what should I call this new mustang?
the "2007 Ford Shelby Mustang Cobra GT 500???"
Come on, Ford. Sometimes Less is More.
