Go Back   Automotive Forums Car Chat > Honda > Integra
Old 03-23-2005, 03:35 PM
CRXGRETH's Avatar
CRXGRETH CRXGRETH is offline
Send a message via AIM to CRXGRETH Send a message via MSN to CRXGRETH Send a message via Yahoo to CRXGRETH
engine miss at high revs?
alright i have a 87 crx wit and 87 integra engine and it is bored 30 over and im running 45 lbs of fuel at and idle and 60+ over 1500. free flow exhaust cold air intake, it has a miss when the motor is over 3000. but it purrs at an idle. i check the plugs and they are burning clean?
Old 03-23-2005, 04:43 PM
slow_99integra's Avatar
slow_99integra slow_99integra is offline
Re: engine miss at high revs?
did you check to see if you are running lean/rich?? did you check your fuel pump, lines, filter?? check all vaccuum lines and sensors. check to make sure the timing is correst my 99 is 16 degrees before TDC (Top Dead Center) hope this helps
They say "speed kills drive a Honda" I say "You're right"
"I'm a kid with a grown man's mind turning corrupt" Wu Syndicate
Old 03-25-2005, 09:01 AM
Si Integra Si Integra is offline
Send a message via AIM to Si Integra
Sounds like you are running rich. Do you habe an aftermarket ignition? Typically that ends up as a distributor problem on the obd0 Tegs.
Test the fuel mixture (depending on the age of the plugs, they may not show much), the disty (more than likely the culprit), and then try lowering the fuel pressure a bit.
Other things to consider:
leaking injectors
fuel pump
main fuel relay
Plug wires
Good luck!
Old 03-25-2005, 04:04 PM
CRXGRETH's Avatar
i did check the fuel lines and they are all clear. i don't have an aftermarket ignition but was planning on running a msd 6 ignition. checked the plugs and they are all liike a lbrown color. now when i pulled the plug nearist the distributor it did have a lil oil on it. and i checked my computer it is also givein me a code 10 which in alldata says it is my air intake temp. so i went and checked it and it was snipped and the wires ran to the underside of the intake so i reran them to the sensor and reset the ecu and then it went out for like 3 mins and was back with the same code. So what is my next move?
Old 03-26-2005, 12:25 PM
I would consider replacing it. The wires may have been cut to avoid other problems by a novice mechanic. There is a slew of things it could be. You will litterally have to go step by step checking them all I suppose. It is hard to diagnose a problem you are nto there to see. i hate to overlook something minor and lead you in the wrong path;hence, i try only to suggest a few things that could pertain to your situation. Do you have a helms manual? If not, i recomend purchasing one, they are a huge help. I have several and I use them on all the hondas I work on.
It is quite simply put, the honda bible
Old 03-30-2005, 08:24 AM
CRXGRETH's Avatar
all right i figured what it was i went threw a puddles and then my motor shut off so i figured i suck water into the intake so i let it sit for 5 mins and its starts and well lets just say i know need a motor for it plus i think the wire harness is screwed up on the one i have now so my question is a do i replace moter in this one or do i get either a 91 crx si wit the sir motor and turbo wit 5 spd or a 93 civic 2 dr coupe wit the sir motor turbo. either one of them is a quick car but i also want some dependable stuff tho.
