Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 03-23-2005, 03:29 PM
jchavis jchavis is offline
Unhappy Car wont idle when it's cold.
I know that old car's usually need to warm up but it sucks. Anything i can do to avoid having to warm my car up every hour untill it gets enough heat to idle?
Old 03-23-2005, 03:50 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Re: Car wont idle when it's cold.
Is it that it won't get warm at all, or does it just idle high until it's warm? If it's not idling high enough, just adjust your idle screw a little to kick the rpm's up slightly.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 03-23-2005, 04:52 PM
It will idle fine once it is warmed up. It idles at about 1200 or so after it warms up. So its just the cold idle that's not working. It jumps when you intially start it to about 2000-2500 then it dies back down.
Old 03-23-2005, 04:57 PM
Figori's Avatar
Well... You might want to adjust your idler screw slightly.... It should idle around 800 when warm... So... Maybe that could help.
Old 03-23-2005, 07:26 PM
The problem isn't the warm idle. Its runs a little high but it's the cold idle. im going to try and use some carb cleaner on the linkage to see is thats the problem. Thanks.
