1996 V6 to LT1`
Hey all, it's me again. Previously I had inquired about putting a 455 into a 4th gen: http://www.automotiveforums.com/vbul...d.php?t=380379
Well, that idea is now defunct as i managed to get an LT1 from a Cadillac Fleetwood off of Ebay for 350.00. I've still got to get the wiring harness and computer, as well as exhuast manifolds. I'm also gonna switch out the iron heads for the aluminum ones that came on the Firebird and Camaro. I'm currently making a list from a list I remember reading from a website where a guy did a swap with his black '94 firebird equipped with a 3.4, whereas mine is a '96 with a 3.8. So far my list of changeouts contains: Swap two piece driveshaft for stronger one piece Radiator Swap rear end Change rear drum brakes to rear disk If you know of anything else that i need to add to the list or remove let me know. The biggest question I have so far is whether the transmission, 4l60-E, will bolt to it. I've read conflicting things on whether the bellhousing will bolt up or not. I've also heard that if you have to switch bellhousings you might as well get a new transmission. I've also read where most people say that you have to drop the engine and transmission out the bottom, yet I've seen pictures of people removing and putting the LT1 in from the top. I realize it's probably not as easy as just jacking up the car and droppping it, but pulling it from out from under the hood just seems like it would be easier in the driveway. Once again, any and all help is appreciated......unless it's just to say sell the car and buy one that already has a V8 in it, because that response is no help to anyone. John |
Re: 1996 V6 to LT1`
you have to look into whether you have a tranny with a bolt on housing, if not you will need a new tranny. dont think the bolt on housing came on f-bodies til later, so you will more than likely need different tranny.
as for the pullin of the engine, apparently you can pull from the top when you remove radiator and stuff. heard that is how chilton says to do it, i have the GM service manual and can look it up for you if you want. the camaro/firebird LT1s did not come with aluminum heads, as far as i know. you can get aftermarket heads that are aluminum though swap list: fuel lines fuel pump shocks springs front crossmember the power steering gear box(not necessary) gauge cluster heater hoses exhaust obvisously ECU and harness
*Better power-to-weight ratio than a C6 corvette* |
Re: 1996 V6 to LT1`
actually chevyracin.. the LT1 F-Bodies did come with aluminum heads
![]() "doing that is like trying to sell porn to a 6 year old..... It's just wrong" - hypsi87 LE123456712: i promise i will stop filling your email with my boobs Kieft125: lol.. good, its starting to get rediculous.. |
Re: 1996 V6 to LT1`
I have a 93 Cadillac Fleetwood. Just curious, does that have an LT1 in it? I know it's a 5.7L.
-2004 Cavalier LS Mods: Weapon-R Short Ram, Shift Kit, Nitrous Express Wet Kit, Upper/Lower mounts. Audio: 15" RE .SE sub to BRUTUS 1500, 6.5" RE components in the rear, Apline's in front, all to Pheonix Gold Profile, Alpine deck. ![]() -1997 Sentra XE, 5-speed POS, commuter. |
Re: Re: 1996 V6 to LT1`
Re: 1996 V6 to LT1`
Jadefirebird what website has the 3.4 to LT1 conversion?
2010 ALCAN 5000 driver I own or have owned: 98 Ram Air firebird-WS6 hood and rear decklid, WS6/C5 vette rims, etc. 03 SRT 4-3'' exhaust, short throw, injectors, matte black E36 convertible BMW-05 17'' BMW wheels 02 Volvo S60 AWD turbo-Stock 00 Audi A6 4.2L V8 Quattro-Potenzas, straight pipes 03 C240 Benz 4matic-stock 04 2.5rs Impreza 05 Chrysler 300C HEMI 04 GSXR-Power commander, K&N, gears, crash cage, suspension, LED tail |
Thanks chevyracin and everyone else. The website was v6swap.com i believe. it doesn't exist anymore near as i can tell, kicking myself for not copying the whole website to my computer. I ran across it a couple years ago. He had listed everything he used for the swap, even what he bought to upgrade, like Posi and such, and how much he paid for them on ebay. He also had good pictures of his swap. he was using a '94 Black V6 firebird. i remember he ran into some interesting complications as the LT1 he had came from a '96 model with the dual cat setup.
