Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 03-23-2005, 02:14 PM
stevefx19 stevefx19 is offline
Send a message via Yahoo to stevefx19
Cat. Converter
If you cut a cat. converter off of a car that may be clogged and replace it with a piece of pipe from autozone will it run better? Also will it make the exhaust louder even with the muffler attached?
Old 03-23-2005, 06:48 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Cat. Converter
If your car is designed to run with a cat. then removing it will cause problems if you have a computer controlled car. If you are concerned about better flow to scavange exhaust replace it with a high flow cat. This will do the same job as removing the cat and replacing it with a straight pipe although it will cost more. But it may save you a lot in the long run.
Old 04-03-2005, 01:12 PM
pontiacfreak_81 pontiacfreak_81 is offline
Send a message via AIM to pontiacfreak_81 Send a message via MSN to pontiacfreak_81 Send a message via Yahoo to pontiacfreak_81
yes thats good advice, DONT remove the cat and just put in a piece of pipe, i did this with my 93 sse and it ran terrible, was really loud (not even a good loud) and my gas mileage dropped to about 18 m.p.g. on the highway.
Old 04-03-2005, 01:31 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Cat. Converter
It depends on the car. If you have OBD II EFI system (required after 1995 or so, the car won't run properly. However, if the car is older, removing the cat will not harm the way it runs. OBD II systems usually have an O2 sensor downstream of the cat. Older systems do not.
The car will be louder though.
Realitically, converters are pretty cheap these days. If the old one has gone bad, help save the air we all breathe and install a new cat.
