Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani > Modifications/How To
Old 03-23-2005, 01:17 PM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
I4 Header install DIY
This DIY is for the aftermarket i4 header installation.
Here we go.
1st: Disconnect the battery. The ECU will be reset once you finish the install and hook the battery back up.
2nd: You will need the headers. lol
3rd: Take this ugly thing off by removing the 4 screws.
4th: You should have something like this.
5th: Start removing the 9 nuts that hold the header in place. Its a pain to get to the one nut on the far left. Keep trying. Dont forget, you have 2 nuts at the bottom to remove.
After you finish, you should have this.
6th: You have to disconnect this part.
7th: Unscrew the other end
8th: You schould have this.
9th: This piece should fit right onto the new header. Something like this.
10th: I had trouble with this one. The headers that I got didnt come with the screws for some reason. The screws on the OEM header cant be removed. Only the 2 nuts can be.
1th: SO, I went to Home Depot and bought 2 screws that match the nuts. Look in the pic.
12th: Put the new header in place.
13th: Start puting on the nuts back.
14th: Dont forget the bottom ones.
16th: Should look something like this.
15: Next is putting this piece back.
Connect the battery back.
16th: You are done.
This is really easy to install.
almost that time
my sig made mommies cry, thats why i had to change it..
