Go Back   Automotive Forums Car Chat > Nissan > Cedric | M45 | J30 | Gloria
Old 03-23-2005, 10:03 AM
jada1023 jada1023 is offline
96 j30
I have a 96 j30 bought new in 96, no problems until this year. car idles down and cuts off, have had diagnosis done by nissan dealer, they couldn't find problem. I have had catalytic converter installed, fuel injector service. carbon cleaned on egr, egr replaced as well as egr temp sensor. Put in coils last year. as well as fuel pump. but i noticed in the forum that its bad to drive the car past a quarter tank. would this have made the pump bad again. when driving on the interstate the car appears to miss but doesn't drive bad.
Old 03-23-2005, 12:29 PM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 96 j30
Originally Posted by jada1023
...car idles down and cuts off, have had diagnosis done by nissan dealer, they couldn't find problem. ... but i noticed in the forum that its bad to drive the car past a quarter tank. ...when driving on the interstate the car appears to miss but doesn't drive bad.
- if that 'cut' is sharp, most probably its in electronics like bad ign sw, ecu pwr supply relay, cam pos sensor, wirings to those or main fuses. (One dead injector or plug causes only sputter.) Check out whattoDIY with connectors, relay connectors, groundings.
Read: http://www.cardomain.com/memberpage/748507/14 and
http://www.cardomain.com/memberpage/748507/10
- Fuel pump makes noise, listen. Pressure up: the fuel hose feels stiff.
- nissan stealership? lol. Get filthy rich - never visit that shop.
- quarter tank? must be the 'magic men evening stories'... Its worse when tank goes empty - must start pushing. (Some of them even try to tell ya engine sparks are bad; now try to drive without...)
- probably this miss is unrelated, maybe. One plug bad?
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 03-23-2005, 12:38 PM
Question Re: 96 j30
It sputters on startup and idles out or when turning a corner almost like out of gas.
Old 03-23-2005, 12:45 PM
krin_mage krin_mage is offline
Another Thing It Coulf Be Is The Mas/iat Sensor. It Is The Mas Air Flow Sensor And Intake Air Temp Sensor Combin. If It Starts To Go Out Then You Wont Be Goin Anywhere. Have It Tested Just To See If Its Not The Check The Plugs Anddistrib Cap
Old 03-23-2005, 01:41 PM
Re: Re: 96 j30
This changes the whole vista: Like said, maybe also MAF and/or O2.
If its only when COLD, its Throttle Pos Sensor TPS:
http://www.cardomain.com/memberpage/748507/6
- Test sensors
- Do ECU selftests
