Old 03-23-2005, 08:16 AM
huntertwo huntertwo is offline
1998 taurus heater prolbem
I have no idea what to check for.
My heater only warms a very little.
Temperture gage stay below cool setting not moving much at all.
cooling fluid is fine.
Anyone have any idea's for me to check?
Old 03-23-2005, 09:02 AM
sfontain sfontain is offline
Re: 1998 taurus heater prolbem
I'm not an expert on cooling systems, but here is my opinion: Your thermostat may be stuck open or is opening too early, or your cooling fan is staying on.
If you change your thermostat do so with a *Ford* part, not an aftermarket one. I suppose this is the first thing I would try. Unfortunately, this will mean draining your coolant.
If your radiator fan is staying on, you may have a bad coolant temperature sensor. But I doubt this; as I understand it, these sensors usually fail the opposite way, telling the PCM that the coolant is extremely cold, so your fan wouldn't come on at all and may cause an overheating condition. Anyway... In my car (2002), I can hear the fan spin down at idle after I've been driving for a while; additionally, there is a slight bump in the RPMs when it turns on or off. If you can hear it turning on/off properly, this obviously isn't the problem.
I would lean heavily toward a new thermostat. Instructions for replacement will be found in a Haynes or Chilton manual.
*edit* I've changed my mind. I completely believe you need a new thermostat. I think even if your fan were staying on, if the thermostat were staying closed when it was supposed to be closed, no coolant is entering your radiator to be cooled by the fan.
Old 03-23-2005, 11:57 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Good answer sfontain. The big indication there is the temp gauge not going up to normal operating temperature. Try thermostat first. It is a simple repair.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-23-2005, 05:57 PM
Re: Re: 1998 taurus heater prolbem
Thank you thats what i thought just wanted other thoughts.
Old 03-25-2005, 04:23 PM
AJReid AJReid is offline
One thing I found with my 98 was a broken mixing door in the plenum that controls the cool/hot air ratio. Replacement for the whole unit is $$ but I have heard you can buy just the door now. Crazy glue worked for me.
