Old 03-23-2005, 02:22 AM
commander100 commander100 is offline
Is my oil pressure too high?
I searched the forum and couldn't find this problem addressed.
I have a 1995 blazer, 4.3L V6 4-dr 4X4
My oil gauge reads 70 when cold, 60 when warm. I also have a leak in the front oil cooler line to radiator. I replaced both sets of oil lines about 3 years ago. Is it common for the lines to only last 3 years?
I was told by my car dealer that the oil sender was probably bad, causing the high readings. Could the readings be accurate? And could this be the cause of my lines leaking again? It is a very small leak (one drop), and doesn't happen every day.
I am thinking maybe the oil bypass valve isn't working correctly?
Is there a way to check the actual pressure? And where exactly is the sender? My manual says the top left near the distributor, but I don't see it.
Thanks
Old 03-23-2005, 08:48 AM
herkyhawki herkyhawki is offline
Re: Is my oil pressure too high?
it threads into the top of the block, behind the intake manifold, where the back inside corner of the driver-side head meets the block. It is 1/8" npt thread so you can adapt fittings to put a pressure gauge on to read the actual pressure. Then compare this to the dashboard gauge.
Old 03-23-2005, 10:49 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
What oil and filter are you using?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-23-2005, 11:10 PM
I'm using mobil 1 oil 5W30 and AC delco filter.
Old 03-23-2005, 11:17 PM
BlazerLT's Avatar
AF -Advisor
When are these pressure reading being taken?
Idle? Driving?
Old 03-24-2005, 01:04 AM
70 when driving and when idling cold
60 idling warm
Old 03-24-2005, 01:07 AM
I'm also running the K&N FIPK cold air intake. Flowmaster cat-back exhaust
Old 03-24-2005, 01:34 AM
BlazerLT's Avatar
AF -Advisor
Is you engine getting up to temperature?
The temperature should be on or two ticks to the left of the 1/2 mark when the engine is warmed up.
Old 03-24-2005, 12:02 PM
Yes the engine gets up to temperature
Old 03-24-2005, 12:14 PM
BlazerLT's Avatar
AF -Advisor
I would consider adding a bottle of engine flush to the oil and idle it for 30 minutes before you next oil change to dissolve any restriction in your oil system.
IDLE ONLY
Old 03-24-2005, 10:59 PM
Yes, I already bought the stuff today.
Old 03-25-2005, 02:57 AM
BlazerLT's Avatar
AF -Advisor
Good luck.
Follow the directions.
Old 03-26-2005, 01:35 AM
Engine warm
Idle 35-40
Highway 60
This did help. Hopefully enough that the hoses will not leak anymore.
Couldn't tell the fresh oil from the 3000 mile oil after the cleaner was used. Truck smoked alot while running the cleaner, too. First time I did this. Truck has 83,000 miles.
Still can't find the oil sender sensor. Should I be looking from the top or bottom of engine? Is it between the engine and the firewall?
