Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-23-2005, 01:48 AM
monooxide's Avatar
monooxide monooxide is offline
Banned
Send a message via AIM to monooxide Send a message via MSN to monooxide
Going Crazy?
Am i going crazy or what? I think im just scaring myself i jsut need reassurance. Ive heard of 240s having ticking but not until like 160k+ miles. Im at 140k... and I dont hear the noise when im in my car hardly...but with the window down i can hear it and when im outside the car and when the hood is popped. Its a ticking but shouldnt a valve tick get progressively worse? Man....just had a friend blow a water pump and another throw a rod...I really dont wanna be in that boat!
Old 03-23-2005, 01:55 AM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
Define "tick". Does it actually sound like vavle tick from the top of the engine or does it sound like it's coming from someplace else?
Also, given hydraulic lash adjusters, a common explanation for valve tick is low oil level. Check the easy stuff first.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 03-23-2005, 08:01 AM
Chuki_breath Chuki_breath is offline
Re: Going Crazy?
or its just the infamous timing chain guide tick. Common, all 3 240's at my house do it. Some worse than other though. All you have to do is remove the guides. The tick sounds as if its coming from right up front of the head right??
Old 03-23-2005, 09:25 AM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
Re: Going Crazy?
My Injectors are Louder than my Lifters
I scare my self into hearing lifter tick nearly every day.
Old 03-23-2005, 12:46 PM
SHIFT_KA24DE's Avatar
SHIFT_KA24DE SHIFT_KA24DE is offline
Re: Going Crazy?
yea my 93 has 181k... it ticks like mad.
...jus wonderin' why does it do that? since removing the guide solves the problem... is the chain moving? or loose? what's goin on?
1993 RMS13 5MT KA
Old 03-23-2005, 01:27 PM
monooxide's Avatar
Banned
yea...
I know im not low on oil. I think i remember putting my head down near the head and wanna say it sounded like Back of 2nd or Front of 3rd cylinder....But if its the chain guides how easy are those to replace and how would i tell if its them when i took it apart? Just the wear on them?
Old 03-24-2005, 04:51 AM
DAS14SNIPER DAS14SNIPER is offline
I Got The Same Noise
But I Started To Hear It When I Changed The Waterpump
I Thought It Was A Loose Belt Cus I Hear When The Rpm's Go
Down, Like If Its Loose Bearing Or Valve
I Checkd The Belt, Tested It And Its Fine
Im Thinking Of Taking The Pump Off And Running The Engine To See If Thats My Problem.i Doubt Its A Chain Guide U Wont Get A
Ticking Sound.
Old 03-24-2005, 06:13 AM
monooxide's Avatar
Banned
umm
I had a rattling noise on my exhaust shields on my header-Catalyic Converter....but if its ticking iunno....
Old 03-24-2005, 01:05 PM
logik23's Avatar
logik23 logik23 is offline
Banned
Send a message via MSN to logik23
Re: Going Crazy?
If it is the chain, don't worry about it to much, it won't break or anything, but if you wanna have it fixed, it's a bitch and it's expensive, well on an Altima, I dunno about a 240, prolly similar.
Old 03-24-2005, 02:44 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: Going Crazy?
Injectors. They are loud as hell.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 03-24-2005, 05:30 PM
Re: Going Crazy?
im telling you its prolly the guides. I heard a story of one guy having his chain guide fall off in his head, and it was just sitting there rubbing his chain making the noise. I think its fairly easy to take the guides actually off. But if your going to do the whole chain, well then....
I think there are just a couple of screws that hold them on. I dont know ill try to find where i read this info.
