Old 03-22-2005, 09:40 PM
mrgofast21018's Avatar
mrgofast21018 mrgofast21018 is offline
Send a message via AIM to mrgofast21018
transmissions
just wondering what everyones opinions on trannys is. whats the best? and what makes it better than the others?
Old 03-22-2005, 09:42 PM
travagliante's Avatar
travagliante travagliante is offline
Re: transmissions
What is the best? Depends on what you need it for?
Longer gears=slower accel, but better gas mileage and lower highway rpms, higer top speed
Shorter gears=fast accel, bad gas mileage and high highway rpms, plus you top out lower
Old 03-22-2005, 09:46 PM
Re: transmissions
not really looking for any one specific thing. just wanted to know what some desirable trannies are and why they are desirable.
Old 03-22-2005, 11:31 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Re: transmissions
ah my auto crusies down the highway at like 3.5k-4k rpm going about 80 or so
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 03-22-2005, 11:50 PM
Re: transmissions
People usually want Si transmissions. They are similar to DX.LX ones but the final and 5th gear is closer/shorter. It accelerates much better also.
Are you talking about a stock engine?
Some people also like the dohc zc lsd tranny, but thats hard to find! But stock Limited Slip!
If your talking about b-series engines. People go after 92-93 Ys1 GSR transmissions(there are geared like an ITR) or an ITR tranny, also the super short JDM S1 tranny from an Honda Integra XSi, or even the SiR y1 tranny with LSD(...the one i have)
Old 03-23-2005, 12:15 AM
LOUDCRXSi's Avatar
LOUDCRXSi LOUDCRXSi is offline
Send a message via AIM to LOUDCRXSi Send a message via Yahoo to LOUDCRXSi
Re: transmissions
well im opinion is the USDM CRX Si tranny. i mean with the d16a6 engine....its straight. i like it. the gears are real short and the only tranny i have found that has the closest gears to compare are the JDM CRX Si tranny. although the LSD tranny is of the hook i think without LSD the CRX Si is the best tranny. And if ne body disagree's dont get pissy its just a personal opinon. The bad thing about the CRX Si tranny is the fact that at 60mph you are at 3000 rpm. its kinda hard on ur motor. but if you have 2 vehicles like me its ok..... you just take out ur other on when you go on the highway.
im thinkin that the integra GSR tranny is the best. only b/c the GSR integra runs a 15.2 (I THINK!!!! i might be wrong) so it must be somin between the hp and the gear ratio. i hope this is some help.
Old 03-23-2005, 08:48 AM
aftershock192 aftershock192 is offline
Re: transmissions
i personaly think a hybrid tranny is best. It uses an si and a zc tranny. You use the si case so you can keep your axles(zc is an option so you get equal length axles) You then take the zc gears 1 though 4 and the si 5th and final drive. To make a very quick tranny and still have the si highway gas mileage. On my crx i have a d16z6 in it and plan on getting a jrsc and what ever else i need to hit about 200 horsepower. So i might put an hf first gear in it for easier traction control then use a zc 2-4 gear followed by the si 5th gear and final drive but i not sure about that. At the moment i have an si tranny and love it later
90 hf current mods: 94 civic ex engine, darkstar front crossmember, adj fuel pressure regulator, intake much more to come
Old 03-23-2005, 09:20 AM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Re: transmissions
i love my dx tranny, they are not as bad as some people say. i plan on turboing my car within 6months or so , the dx will be perfect, i wouldnt have to jumb through gears like a mad mad. a si tranny is good for a track (drag or auto-x).
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
