Throttle body gasket question
I am looking to swap engines from a '94 manual (upgraded emissions) to to a '94 automatic (standard emissions). It would seem to me that the easiest way to swap the throttle bodies would be pull the throttle bodies from the intake manifolds instead of pulling off the entire intake manifolds. The problem I have with this, I would probably have to replace the throttle body to manifold gasket. Does anyone know if this gasket is sold seperately or do I have to buy the entire gasket kit?
Re: Throttle body gasket question
there are 2 throttle body gaskets on the 94, there is the one between the body and thermal plate and another between thermal plate and manifold. i was able to get both from napa for about $2 each. make sure when they give you the gasket it only has the 1 big hole in the center. often they try and pawn the 2 center hole one off on you (89-93)
Excellent info, thanks for the help!
