Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-22-2005, 08:02 PM
ricebrnr13 ricebrnr13 is offline
need help with cams.
what cams are you guys running? i want to get more top end but also want to have stock idle and i'd prefer not to change valve springs, but i will if need be. oh yeah the cars a 2g tsi.
Old 03-29-2005, 03:35 AM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
Cams
There are so many variables... What else do you have done to the car, or what are you planning on? I've heard Crower cams are great (http://catalog.exileracing.com/index...acturers_id=81) , so I'm getting Stage II Crower Cams... Stage III (the highest) will have horrible idle problems for a street car, but Stage I isn't agressive enough. They also have turbo grinds for the Stage II... The higher the stage, the more high-end power, basically... just don't overdo it.
Even with the Stage I Crower cams I'd recommend titanium retainers and valve springs. This prevents a valve from being held open because it can't bounce back quick enough.
Hope this is helpful!
Old 03-30-2005, 05:50 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: need help with cams.
Idle will always be different from stock, no way around that. The question is WILL it idle I ran HKS 264s, and 272s. No difference in idle that I could see hear or feel. I Didnt measure the vacuum though. I see no reason why someone wouldnt go right to the 272s and be done with it. Or the equivelent from another manufacturer. Neither of those two require valve springs.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-30-2005, 05:58 PM
2of9 2of9 is offline
are installing Cams pretty hard? sorri if its a newbie question.
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 03-30-2005, 06:01 PM
AF - Advisor
RRE has good instructions. Might be in the vfaq too.
Kevin Jewer
Old 04-02-2005, 04:45 AM
Whathits14 Whathits14 is offline
High top end cams would be the stage 2's or a set of HKS 272's. These are both aggressive STREET cams. Cowl also makes some good 4g63t cams. Another option if you are a 2g is to put on a 1g head. The 1g heads are better: flows better, stronger and had slightly more aggressive cams. 272's will give u lots more top end. With a decent amount of mods, it is not uncommon to see jumps of 50 ponies when installing some HKS 272's
The 4g63 engine is extremly stable, and u probably won't need to upgrade valves, springs, or retainers untill you hit about 350 horses. It isn't uncommon to see stock blocks putting 4hundo ponies to the ground.
