Old 03-22-2005, 08:50 PM
91StealthStress 91StealthStress is offline
Unhappy Low Oil pressure???
I Own a 91 Dodge Stealth and despite other problems the most concerning is my oil pressure. When I start the car it is about one tick above the lowest it should be and after it warns up it becomes very low. I am running 20w50 in it and still the problem. I think it must be the oil pump. Do any of you have information on installing an oil pump. or other ideas.
Old 03-22-2005, 08:55 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: Low Oil pressure???
Wow yea don't drive it, maybe its just the gauge but you should get your actual oil pressure checked, mines being done tomorrow because my gauge goes a bit nutty somtimes.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 03-22-2005, 09:35 PM
crazy_quick crazy_quick is offline
we all got low oil pressure, come with the 3/s territory.
and all of the guages are straight up crap.
Old 03-22-2005, 09:36 PM
sLADe781 sLADe781 is offline
I'm beginning to worry about this whole oil pressure deal because the line that connects to my sensor can't be found so my oil pressure gauge doesn't work at all. And since everyone is having problems with it, what if I am too and just don't know it!?!
Old 03-22-2005, 10:11 PM
Igovert500's Avatar
blue + red light magnet
Well a 20w oil will thin more than a 10w once the car reaches operating temps...but that probably isn't your entire problem...you are describing what to me seems to be quite low oil pressure.
Some say this is normal, I know mine drops once the car is at a warm idle, but never as low as you are describing...however, I have heard others say theirs has.
So if yours used to be higher, than definantly don't drive the car until you fix the problem, as low oil pressure is the number 1 cause of spun bearings.
The stock gauges are notoriously pretty cheap...they are slow, and it is a good idea to upgrade to an aftermarket one to properly monitor changes.
So just starting with the basics...are you leaking oil? Check in front of driver's tire (common oil leak from the oil cooler lines that I am currently dealing with, it can also leak out the exhaust in older mileage cars...will show up as blue smoke.)
Did you check your oil level? (sorry if this is redundant...I don't mean to insult your intelligence...just making sure)
Also what does your engine idle at when warm?
Slade...check this out:
http://www.3si.org/forum/showpost.ph...85&postcount=6
That might help trace the line...but I would get a working gauge soon...but don't panic
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-22-2005, 10:21 PM
Thourun's Avatar
I think you'd hear it lol, just get the gauge fixed! If that dosent work get an aftermarket oil pressure gauge.
1995 3000GT VR-4
Old 03-23-2005, 12:20 AM
Yeah, I think mine is like lost forever. Hehe Because I remember over the summer, Musashi was trying to help me locate the line but we couldn't find it. I found the sensor but couldn't find the line so no connection was made. Well, if anyone has any other ideas of how I could find the line (if it's even still there), let me know. Thanks. But yeah, speaking of Musashi, anyone heard from him recently? Haven't seen him on much since he posted the problem with his car again. I think I'll PM him....
