Old 03-22-2005, 07:35 PM
TB55123 TB55123 is offline
Keyless entry code
Is there a way to determine the keyless entry code on an 2002 Silverado Z71 without the remotes?
Thanks.
CGM
Old 03-23-2005, 03:39 PM
tayloel tayloel is offline
Re: Keyless entry code
It should be
GM/LEAR: 15042968
FCC ID: KOBLEAR1XT
CANADA: 3521 102 1718
Old 03-23-2005, 03:41 PM
Also, you can pick up replacements on Ebay for ~$15 each. The dealer charges ~$60 each.
Old 03-23-2005, 09:49 PM
yep that's what I'm tryng to do, purchase openers on ebay for my recently purcashed 02 Z71. The codes should be on the vehicle somewhere shouldn't they?
Old 03-24-2005, 05:03 AM
jethro_3's Avatar
jethro_3 jethro_3 is offline
Each fob had it's own signature. I did it once and can't find it now but I believe you turn the key on/off three times and then a specific key (lock/unlock on the door, can't remember if that was it) and then you touch the open and close on all the fobs you will be using, each one in succesion. The computer will time out and only the fobs used in that session will work as now the computer will only recveive from those fobs. Some dealers try to charge you but it only takes 2 minutes and no tools.
I will try to find the papers I have. Good luck.
"The Sleeper" '05 6.0L VHO
Cam in and
Low 14's happening at the track
Check out my Ride
Old 03-24-2005, 07:51 AM
airjam18 airjam18 is offline
This thread has instructions....I used these to program my remotes since I only had one and I got another as a spare........It only takes a minute to do......good luck....
http://www.automotiveforums.com/vbul...rogramming+fob
