Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 03-28-2002, 09:10 PM
Stogie82 Stogie82 is offline
Send a message via AIM to Stogie82
Throttle Body Cleaning...
Well I was gonna take advantage of the long weekend and clean my tb but didn't order a gasket from Infiniti. I have looked everywhere trying to find out if I can just get some gasket material and make one or would this be bad? If I do go this route which size would I need? Does anyone have any advice? Also any more suggestions regarding cleaning your TB and replacing fuel filter. Any problems I might encounter? I have already read eveything on se-r.net by the way. Thanks for any help in advance!
Old 03-29-2002, 03:45 PM
lukeyc3 lukeyc3 is offline
do you need a gasket?
I haven't done it on my G20 yet but where is the gasket that needs to be replaced?
It should be
1. remove the clamp screw
2. Move stuff away from the opening
3. grap toothbrush and clean with tb cleaner
4. put back together
no?
I have done this on other cars and never needed a gasket...
when it comes to cleaning the tb, I would use a toothbrush and have a lint free cloth to wipe the sludge that will build up, try to also clean the plate as well...
Old 03-31-2002, 09:26 PM
I think that will work but I wanted to take the TB completely off to clean it and the FSM says replace the gasket. I haven't gotten around to it yet. though.
'00 cavalier, odd noise and oil in air intake/throttle body warik Cavalier Problem Diagnosis 4 04-23-2009 06:11 PM
Throttle body cleaning... how to? gnailuh Off-Topic 9 03-07-2004 03:57 PM
turbo throttle body cleaning 402K Off-Topic 1 02-05-2004 12:28 AM
throttle body cleaning gone bad on a Del Sol 1.6 SOHC KrazyGoku '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 04-06-2002 05:34 PM
Throttle body Cleaning poppy_morenito Engine 3 04-20-2001 09:49 AM
