Go Back   Automotive Forums Car Chat > Volkswagen > GTI
Old 03-22-2005, 05:47 PM
jambohi jambohi is offline
Send a message via Yahoo to jambohi
my gti vr6 wont start help
i have a 95 gti vr6 i just changed the coil and the motor still wont turn over i need help bad i also changed the crank sencor, if anyone has any information on the problem please help so far the only thing I have had any luck with on this problem is no solution
help
Old 03-22-2005, 05:48 PM
Re: my gti vr6 wont start help
Help Gti Will Not Start
Old 03-29-2005, 03:28 PM
jinnahflaxi jinnahflaxi is offline
help
I had same problem with my GTI,changed all sorts but turn out to be it was ECU.
Look for replacment ECU and don't forget to get key reader too
Old 10-25-2005, 11:49 PM
Rob32 Rob32 is offline
some help
hey whats up buddy i had a vr6 i miss it so much ok anyways before u look into changing your hole ecu make sure its not the fuel pump or fuel pump fuse just turn the key to the on pos and see if u here the fuel pump come on for about 2 seconds if u dont check the fuse it should be number 18 good luck
Old 10-27-2005, 10:49 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
are u sure you have the wires hooked up right?
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
