Old 03-22-2005, 04:25 PM
Huss76 Huss76 is offline
Unhappy Cold Ticking...
Just recently I got a ticking noise on my 1992 c/k 1500, 4.3L V6.
Goes away when the engine gets warm. I have no idea where it is coming from.
Once the ticking goes away runs fine...but I have no idea why it started or what caused it.
Any ideas?
Old 03-22-2005, 04:57 PM
2000CAYukon 2000CAYukon is offline
Re: Cold Ticking...
Typically, a ticking noise when cold is an exhaust leak. As the manifold warms up and expands, the leak goes away. Could be a broken bolt, bad gasket or cracked manifold.
//2000CAYukon
Old 03-23-2005, 12:20 AM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Cold Ticking...
Could also be the lifters or -gulp- piston slap.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-23-2005, 07:11 AM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
Re: Cold Ticking...
Could be exhaust, but my first suspect would be a sticking lifter. Run some engine flush and then change oil. That may cure it.
