Old 03-22-2005, 02:34 PM
dave1243 dave1243 is offline
Send a message via Yahoo to dave1243
radiator fan 94 Dodge Caravan
I don`t think my radiator fan is working (temp goes to half way on the guage and fan isn`t running). Is there an easy way to check to see if it`s the fan or another problem?
Old 03-22-2005, 05:41 PM
A. Souphound A. Souphound is offline
Re: radiator fan 94 Dodge Caravan
The radiator fans won't operate unless the coolant temperature is approx. 210F. Make sure the coolant is getting hot enough.
The Coolant Temperature Sensor (near the thermostat housing) triggers the PCM to turn the fans on. If you have a VOM/DVOM the CTS can be checked.*
Check the radiator fan fuse (40A) in the Power Distribution Center.
If you want to check the fans, you can disconnect them and run a fused jumper wire direct from the battery (+).
*If you decide to check the CTS and need help let us know.
Alvin
A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED.
Old 03-22-2005, 06:58 PM
1thunder 1thunder is offline
Re: radiator fan
to check fan just start engine then disconnect coolant sensor rad fan should start this is built into the pcm program fan defaults on in case of faulty coolant sensor keep in mind a fault code will be generated by doing this so just disconnect battery for approx 20 minutes after to clear codes
Old 03-22-2005, 07:04 PM
thank you for the advice!!!
