Old 03-22-2005, 12:01 PM
pal03 pal03 is offline
91 s10 blazer problem
I have a 91 s10 blaver with a 4.3L TBI. and I am geting about 150-200 km on a tank of fuel and I was geting about 500-600 before now I am just wondering if any one might have some ideas that I could try to find this problem. I am geting alot of black soot from the tail pipe. I tryed a code reader and got a leen exaust code. So I am thinking the O2 might be bad but I have no idea how to test and it was replaced less then a year ago. I will post more info as I get more tests done.
Old 03-22-2005, 09:05 PM
jsgold jsgold is offline
Sounds like you are on the right track, but would check for vaccuum leaks. My 93 with CPI had a drop off (18-20mpg to 15+-) and I found a leaky hose was causing problems with that and my idle.
I used to be indecisive, now I am not so sure.
Old 03-23-2005, 07:42 AM
Jerry80871852 Jerry80871852 is offline
Re: 91 s10 blazer problem
I recently did a check on my 92 S-10 4 x 4 with the W 4.3 engine which is fI.
I went 255.3 miles, 3/4 of it was in the mountains on narrow gravel roads with much up and down steep mountains and around curves at speed of 29 to 35 MPH.
I used 12.188 gallons of gas, which made my MPG 21.1209.
Believe that is right good!
I rightly do not know how the TBI compares to the FI on MPG.
Jerry
