noise in engine, when transmission doesnt shift
the tranny will not shift, only manually ,when you let it try by itself, it wont change, when this occurs it has engine noise, and only when it doesnt shift, will this noise dissapear when tranny is repaired? v 8 262,
just wanted a few opions,thnx |
is it a turbo 350/400?? if so I bet it has something to do with the vacume modulating valve down below
Grand National. Going fast with class. Voted FASTEST street car on AF. Here is the proof!!! 1987 Buick Grand National. Back in action!!!! 1999 Ford F-250 Tow rig from hell 598 Ft-lbs. ASE Certified in... Mobile AC On Highway medium duty diesel engines. Off highwayy medium duty diesel engines. On highway trucks. Working on the eletronics certification Member ofA.A.N.B.C- Afer against non boosted crews #2 |
Re: noise in engine, when transmission doesnt shift
I believe its a turbo 350, itll shift manually, i think the vac from the carb was disconnected from the modulator valve, you think it might be caused by the modualtor? the engine sounds fine otherwise
thanks Hyspi |
Re: Re: noise in engine, when transmission doesnt shift
no vacuum to the modulator valve?? now who had that great idea? |
Volkerc,
are you a complete retard, or just a sometimes thing, why do you always have that nasty attitude? kiss my ass and if the forums dont like it well... DITTO |
And I just realized you are the one that already insulted me and other members in previous posts!!!
Can't believe they still let you in here, at least I know I can't be a retard 'cause my modulator valve is connected to the vacuum source. |
im not tryin to be a smart ass or anything but, common guys, chill out if your gunna fuss and cuss at each other do it with PM's so everyone else doesnt have to see it... -thank you-
as far as the problem at hand... does your tranny down shift by itself or do you have to do that manually to? and is it a continous problem or sort of speratic? as far as the vac. reconnect it, if it doesnt solve anything then the modulator is probly bad... good luck let us know what happens... |
the questionwas only to ask if anyone had a tranmission that wouldnt shift, unless they did it manually ,and when they didnt and it didnt shift, can that cause a chatter type nosie from the engine, the questions not about the tranny, itll most likely be fixed with the modulator valve,maybe because someone had a loose vac line going to the tranny mod?
so voklswagon er eck, if your first reply to this thread wasnt an insult, I apologize. Im man enough for that. but this wasnt the first time youve come off with that 13 year old girl attitude at me, so remember the name its THUMPRKILS just dont reply or talk to me, cause you sure need to stay wherever you are, cause i sure dont care bout ya and last I apologize to any i have offended, if they didnt earn it seems like to me people come off hard to others and if youre not a part of the (buddy system ) then your in trouble, I enjoy being on here and helping those i can, but run that trap at me. dont cry when you get it back |
ps it wasnt even my car mr volkswaggoner
now can anyone answer if this could make engine noise and go away when repaired
it sounds like a crank bearing, but it only makes a noise when its trying to shift and cant, otherwise it sounds and does fine, why is that so hard to grasp?
-Dusty |
