Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 03-22-2005, 07:00 AM
BuckR BuckR is offline
Question Loud ticking after head replacement B2600i
As a result of a cracked head, I had a replacement done and now there is a loud ticking. The shop replaced the lifters on the new head which didn't help. It is much worse when the engine is cold and lessens somewhat when it is up to operating temp. I have heard something about hydraulic lash adjusters etc.. Is there something that can be done or adjusted?
Thanks
Old 03-28-2005, 04:33 PM
sourceunkn's Avatar
sourceunkn sourceunkn is offline
Just a tinkerer here but I wonder if it isn't an oil starvation problem. I guess it depends on how loud the ticking is. My truck ('87 B2600) ticks rather loudly when it is first started (and I'm a half quart or so low on oil) and then lessens when it warms up. Well, I know that oil must coat those surfaces before the ticking will stop and low oil or low oil pressure can cause that.
Anyway, I'm probably wrong but I thought I'd give your post some mileage.
Good luck!
1971 VW Bus (1835cc)
1987 Mazda B2600 (2.6L)
2001 VW Jetta VR6 (2.8L)
2001 Genuine Stella (150cc)
Old 03-30-2005, 05:43 AM
Re: Loud ticking after head replacement B2600i
Good luck!
Thanks for the reply, the shop did an oil pressure test and ruled that out. They are now replacing a lifter (under warranty) I hope that does the trick. You were not the only one with the oil pressure guess.
Thanks again,
Tom
Old 05-29-2005, 09:35 AM
ebworthen ebworthen is offline
Howdy,
Be sure you are putting in the correct viscosity of oil, there is a big disclaimer in the owners manual that if you use the wrong viscosity they are not responsible for damage to the hydraulic lifters.
I tried 20W-50 way back when (like 10 years ago, my b2600i is a 1993) and the valves made some noise. I drove it for a little, then read the manual...ooops! I drained and put back in 10W-30 (I'm pretty sure) and it stopped. With miles it developed a loud tap in what sounds like one valve. I added some detergent oil cleaner and synthetic and it got a little better. My thought is that using the wrong viscosity affected the hydraulic lifters some.
So, make sure you have the right viscosity, try a synthetic or synthetic/dinosaur oil mix (I like Amsoil synthetic but Mobil 1 works), and best of luck!
Old 06-25-2005, 03:26 AM
CanaMark CanaMark is offline
I tracked down a loud ticking once. Changed with RPM. Turned out to be a dented oil pan. Something so easy, yet I did the timing chain. Next up was vibration dampener. Till i gazed under and saw a badly dented pan. Metal shavings is bad
Old 06-29-2005, 01:37 AM
troyjan troyjan is offline
You sound as you are some what of an experience mechanic so I assume you have ruled out the possibilty of incorrect ignition timing.
If the vehicle sat for an extendend period of time you should consider the possibilty of poor octane quality of your fuel.
Ticking noise which decreases after engine warm up generally indicates exhaust leaks around the manifold which cease due to metal expansion from heat.
Old 07-08-2005, 04:59 PM
RussC RussC is offline
Send a message via Yahoo to RussC
Check all the plug wires and coil wire. My coil wire came loose and made a very loud clicking noise as the spark jumped the gap. Truck still ran though.
RussC
Old 07-12-2005, 10:08 AM
Seyfert Seyfert is offline
I dont know if you have found the problem yet, but after I changed the head on my truck it sounded like a diesel engine. I found that the hydraulic tensioner[sic] had become stuck and the chain was slapping around the gears.
