Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 03-22-2005, 01:33 AM
jafowler49 jafowler49 is offline
spark plug gapping
Just wondering what I need to gap my spark plugs to on my 2000 EX. Is it easy to do, are they easy to install? Thanks...
Old 03-22-2005, 10:32 PM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
Re: spark plug gapping
just get bosch +4's they dont need to be gapped, and they are some of the best plugs out there, its an easy job
wait for engine to cool dowm, two hours
unscrew off the black plug wire
take a loooong ratchet, and take em out.
then reverse. 19 ft/lbs i think
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
Old 03-24-2005, 01:07 PM
honda_luvr_2000 honda_luvr_2000 is offline
well to answer the question u asked, 1 mm. that is the honda service manual spec. honda also says to use ONLY NGK or Denso plugs. crap i know it's NGK and i believe the other is Denso, but not 100%. either way u can get them right at the dealer for about $4-6 a plug. so u'r looking at $16-24 for the right plugs for ur car. not a bad deal if u ask me. and yes they r easy to install. as a caution since u sound new to this. do one plug and plugwire at a time. that way u won't get the plug wires in the wrong order (unless they already r) yeah u should also pick up a set of plug wires at the same time u get the plugs from the dealer. a set of wires w/ the "spacers/holders" is about $40. so u'r looking between $56-70 for the best plugs and wires u can get for ur car. again, not a bad deal. as for tightening them down, since u prolly don't have a torque wrench a torque spec is useless, but should be done. just slip the plug into the plug socket and, w/ an extension or two on the socket, tighten the plug down w/o the rachet finger tight. then snap the rachet on and got a quarter turn more. if it feels loose (u can unscrew the plug w/o the rachet) then try another quarter turn. if u over tighten them, u can strip the threads or even bust off the plug. so thats y it's finger tight w/ a qaurter turn more.
Old 03-25-2005, 02:42 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
.039 -.043with NGK zfr5f-11 is where you should be at. pre gapped bosch or any other equivelant plugs will do.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
