Go Back   Automotive Forums Car Chat > Honda > Integra
Old 03-22-2005, 12:13 AM
nu-b94teg nu-b94teg is offline
Tsudo Exhaust
I've had my new Tsudo FIREBALL exhaust and 4-1 header for about a month just sitting the box. Well I just installed them this weekend. The exhaust came with the silencer installed.I was just wondering if there is a certain way to pull it out. I tried just pulling on it with some pliers but it just won't budge. Thanks for your help.
Old 03-22-2005, 10:18 AM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Tsudo Exhaust
It more than liekyl screws in, try to unscrew it or look for some kind of locking screw/bolt.
Old 03-22-2005, 11:23 AM
It has a couple of screws w/nuts. I've removed them and tried pulling on it but it won't budge. Hey Whtteg I've noticed that your sig doesn't say Moderator anymore. Are you still a moderator?
Old 03-22-2005, 07:03 PM
eclipse2quick21 eclipse2quick21 is offline
Re: Tsudo Exhaust
hey man, i have the same exhaust. you have to get a hold of it with the pliers and really yank on it. dont be scerred lol. and how do you like that tsudo header? ive been looking at it for awhile and really wanna buy it. howd it fit, and hows it feel?
Old 03-22-2005, 08:58 PM
the header performs pretty good..I got the header on ebay for 120.00. it was kind of a pain to install but i had it on a lift so i guess that made it easier. I had to unbolt the slave cylinder, removed the fan and even moved the a/c compressor a little. I say it was a pain but in reality it wasn't too hard. The complete install of header and exhaust took about 1 1/2 hours to do. I expected the bolts to be real hard to take off but using penetrating lubricant spray and air tools really helps alot.
Old 03-23-2005, 04:39 PM
Re: Tsudo Exhaust
thanks. did my advice help on that silenceer
Old 03-23-2005, 10:54 PM
i tried a little but then got side tracked. i'll try again tomorrow
Old 03-24-2005, 05:30 PM
Blitz_Runner's Avatar
Blitz_Runner Blitz_Runner is offline
Re: Tsudo Exhaust
i got the same cat-back on my civic and i had to get a screw driver and put it in the hole where the bolts and nuts were and pry it out one side at a time.
Old 03-24-2005, 10:08 PM
I tried putting a screw driver in there as well but still won't budge. The silencer is really pissing me off. Will it make a big difference in sound or performance if I can ever get it off?
Old 03-24-2005, 10:28 PM
K2sInteg98 K2sInteg98 is offline
it will make a difference in sound and performance. The sound will be louder and performance wise, u will have better air flow because there will no longer be anything holding the air in from flowing freely.
Would anyone happen to have a soundclip or know where to hear a soundclip of the tsudo exhaust?
Old 03-25-2005, 03:46 PM
AJ96Integra AJ96Integra is offline
Send a message via AIM to AJ96Integra
Hey nu-b94teg, I see u have the Tsudo headers. I saw those on ebay for like only 130 and wanted to know if you like them? And were they hard to put on (any mods u ahd to do)
96 Integra LS
Old 03-25-2005, 10:41 PM
kelrx8-civicbeater kelrx8-civicbeater is offline
Send a message via AIM to kelrx8-civicbeater
Re: Tsudo Exhaust
its a pain
so do what i did, you know the floor jacks like the 2 ton sliding ones. they come with the bar that has the little stick at the end.stick that end in the exhaust and pully it out.believe before i did this it was a nightmare.
'91 CIVIC
'91 CIVIC SEDAN
'90 CRX SI -sold
'90 INTEGRA COUPE
'04 MAZDA RX8
Maido ST5 20x9 & 20x10
toyo proxes
Old 03-27-2005, 01:11 AM
yeah i tried that stick thing from my floor jack, but still didn't work. Do you guy know if there is a removal tool or if I took it to a muffler shop, that they can remove it?
Old 03-27-2005, 03:27 PM
I just recieved an e-mail from the guy I bought the exhaust from on ebay. He told me to put 91 octane fuel around the tip and then pull it out. He said wd40 won't work. Don't you guys think if I put fuel around the tip and if I still can't pull it out, that the fuel would ignite. I know it won't stay for long but isn't it dangerous?
Old 03-27-2005, 09:57 PM
whtteg's Avatar
Re: Tsudo Exhaust
That has to be the single dumbest thing I have ever heard of. Do NOT put gas on the muffler, it should come out without any kind of lubricant, if wd40 does not do it then you need to use more force, gas will do nothing for you.
